Over the weekend after draining all fluids and removing the driveshafts, I removed the radiator, core support, hoses, and all other attachments to the OEM drivetrain, then lifted the entire unit out of the engine bay with my forklift and engine-lifting gantry attachment. Began the process of installing the new Vintage Air system while the drivetrain was out of the way. Sealed & bolted the Vintage Air firewall plate to the firewall after pre-drilling the pilot holes through the plate. Note - I had to move the 24V buss upwards approximately 3/4" in order for the top evaporator attachment bolt to clear the bottom of the buss. This was the first time I had ever removed the buss and discovered that it is attached with 1/4"-20 nut-serts in the firewall, so I dug out my nut-sert kit and installed two new ones 3/4" higher on the firewall. After reattaching the buss I confirmed that the higher location of the buss would not be too close to the underside of the hood when it is closed. Not even close, so all is good. Then removed the glove compartment per Vintage Air instructions, as well as the dash pad and my custom gauge panel in order to provide access to install the Vintage Air evaporator unit under the dash. Before I could do that I had to remove the OEM heater/defroster unit and related ductwork, and OEM dash control. Once all this stuff was out of the way, it was fairly easy to see how the new Vintage Air unit was supposed to fit. It was at this point that I decided to install foil-backed self-stick insulation to the cab-side of the firewall prior to installing the evaporator unit. I carefully cut the thick cab-side OEM firewall insulation at the transmission hump, removed the large rubber grommet in the lower right-hand corner, and laid the insulation aside temporarily. To install the foil-backed self-stick insulation, I had to produce a cardboard template for the OEM air gate through the firewall, which is now closed by the Vintage Air firewall plate. Got all this done in record time and then wrestled the Vintage Air evaporator unit into place after attaching the mounting brackets and heater hose/refrigerant lines while still on my bench. This was a bear to get into place, so per the instructions, I removed the two bolts which attach the dash frame to the passenger-side windshield frame. This allowed the steel face of the dash to be pulled outward slightly, just enough to allow the unit to be rotated up behind the dash and into place. The attachment bolts were then inserted through the firewall plate from the engine bay by my wife, while I held the evaporator unit in place. By looking through the opening where the glove box was, and using a flashlight, it was easy to see and get the top bolt through the firewall, through the supplied spacer, and started into the mounting plate on the unit. Then the lower mounting bolt, which cannot be seen from anywhere on God's green earth, was started by the wifey while I laid on my back in the passenger floor board and fidgeted the unit around until the bolt head found it's hole. A note of caution - it is very difficult to keep the spacers on the attachment bolts while trying to get the bolt started into the mounting plates. I solved the problem by applying a short piece of duct tape above and below the bolt and across the OEM firewall insulation to hold the spacers in place. After all this, the attachment bolts were torqued on the engine-bay side. Next I will complete the in-cab installation of the Vintage Air system and get back on the process of cleaning the engine bay to receive the new P400 / 765R4 / NP241 drivetrain. Will post photos as I get a little further along.
