4L80E Code 22 and 73
4x4Junkie13
29
La Vernia TX
Trying to get this thing to shift properly, stuck in limp mode.
Codes are:
  1. 22 TPS sensor circuit low
  2. 73 PCS circuit
  • Should I waste time testing the TPS and the PCS or just replace them?
  • When replacing the TPS, does the new one have to be adjusted for it to work properly?
Mogman
10,109
Papalote, TX
Yes you should troubleshoot the TPS, there have been wiring/connector issues before.
Not likely any relationship between the two error codes, just follow the steps in the guide.
I guess I would do the TPS first, when you start to work the #73 check that the control plug at the transmission is not full of fluid first.
Just in case you do not have it.
4x4Junkie13
29
La Vernia TX
Thanks again neighbor. I figured this was the way, just wanted to be sure before I started diving into the checklist.
For code 73, if the connector is dry and tight, is it easy to drop the solenoid and replace?
Mogman
10,109
Papalote, TX
I have no idea but likely fairly easy, but of course you want to troubleshoot it, not just start swapping parts.
Allot of you-tube videos about the 4L80E most of the civy stuff relates to your transmission.
Valley Rock
Big wheeler cat peeler
863
Orygun
While not an expert, if I walked out and discovered my trans wasn't talking to it's two main contributors (tps and pcs) I would check for grounding issues first, I find a simple and effective way to do that is to hook a test light to the + side of battery and get to probin' them grounds and go from there .
Mogman
10,109
Papalote, TX
None of the signals depend on ground, all the leads involved go directly to the TCM.
It could be a lead problem or a device problem or a TCM issue but because he is getting codes it would be assumed the TCM is seeing ground.
Melsride8084
NEPA
I have the same issue where im getting the 73 code, followed the manual and have continuity between the TCM and Trans. Im at the point of swapping out the Solenoid BUT you mentioned the plug being full of fluid. I noticed my control plug into the trans was wet. What does this mean? First time I ever pulled it apart, is it not supposed to be wet? Any help is appreciated.
Melsride8084
NEPA
Hey Meghan I noticed when I pulled the control plug at the transmission. It was full of red transmission fluid. What would this do with that? Give me the code 73? Would that put me in limp mode?
Mogman
10,109
Papalote, TX
I am not sure, others have said this can cause issues although I have not seen it myself, clean it up with contact cleaner and see if it changes.
Thunderbirds
422
Northern Black Hills South Dakota
In my case I had codes 22, 37 and 85. The first two were fixed by adjusting the TPS. After cleaning the connector with contact cleaner the 85 also went away. Make sure you use some di electric grease around the plug after cleaning, ANY fluid could cause a number of issues.
The troubleshooting guide reads:
No DTC
Return Current >0.16A from Commanded Amp
Lasts longer than 1 second
Then it defaults to Max Line Pressure
Hope this helps.
