- 1,076
- 2,057
- Wauchula, FL
Where is your air compressor?
My man has a spare engine in his back pocket so I'm fairly confident he's using pics of that rather than his truckWhere is your air compressor?![]()
Yep, on the rear of the main filter. I just had someone share a video with me of their 3126 fuel pressure problem, sampled from aft of the fuel filter. Getting ~15 psi at idle and barely passing over 30PSI at 2000RPM, so something is wrong in their neighbor hoodā¦On the 2003 3126b M1078A1 the tee is rear of the primary just under the structure carrying the rear cab lockāView attachment 943465
Yes bingo. I like 3D schematics. Not those hard to read sheets of paper.My man has a spare engine in his back pocket so I'm fairly confident he's using pics of that rather than his truck
........ But that IS the (unseen) violence inherent in the system. But we can workshop the marketing a bit...... "The timing sensors are very well protected by the air compressor."![]()
I see. You mean this. Very convenient! Looks like ORB fitting. I'll see if the hydraulic shop has a dampened gauge.Yep, on the rear of the main filter. I just had someone share a video with me of their 3126 fuel pressure problem, sampled from aft of the fuel filter. Getting ~15 psi at idle and barely passing over 30PSI at 2000RPM, so something is wrong in their neighbor hoodā¦![]()
Here's a picture of the teeth and sensors. Old on right. Newer looking ones from crate engine on left. Same cat#'s 109-7194 and 109-7195. Connectors are clean on the harness.This is just ALL pointing to that timing sensor code. The ECM has to "sync" to the timing sensors every time you restart the engine. If the signal isn't stable it will take a bit for the ECM to either see enough of the uninterrupted signal OR for it to give up and switch to a fallback strategy. So the rough delayed start is PROBABLY the timing sensors, wiring, or (woof) the trigger teeth on the timing gears.
I haven't owned a piece of CAT equipment in the last 30 years, but even those simply needed the injectors cracked while cranking. Pumping a primer pump is a new experience for me on a diesel engine on the M1078A1. The last time I pumped to prime fuel was on an outboard motor.Yep, thats it, they made it real easy on the 3116 with a 1/8ā npt port. Had an old oil pressure gauge from the junk drawer hooked up in a few minutesā¦
IMO, this is something everyone should check whenever you change filtersā¦ or install a dedicated gaugeā¦ I don't think I can possibly count the number of fuel supply issues I have troubleshot over the years.
i am kinda surprised cat stuck with the mechanical lift pump on the 3126/C7. Even ford, when they licensed HEUi from Cat fitted a 60 PSI electric pump/filter unit back near the fuel tankā¦ At least that way any leakage leaves a wet spota fixed pressure electric pump could be monitored with a pressure sw and an idiot lightā¦
I'm trying this since no other portion of the seal shows any leakage and there's oil under the nameplate.You might get away with pulling that bolt out and putting a little sealant on it
i wouldnāt āAddā a pump at the tank, I would replace the mechanical lift pump in the governor/HEUI assembly with a 60PSI feed pump and filter at the tank(All electric, no mechanical pump at all) Just so happens Ford makes one of theseI haven't owned a piece of CAT equipment in the last 30 years, but even those simply needed the injectors cracked while cracking. Pumping a primer pump is a new experience for me on a diesel engine on the M1078A1. The last time I pumped to prime fuel was on an outboard motor.
Adding an electric pump near the tank is an interesting ideaā
What the Ford part?i wouldnāt āAddā a pump at the tank, I would replace the mechanical lift pump in the governor/HEUI assembly with a 60PSI feed pump and filter at the tank(All electric, no mechanical pump at all) Just so happens Ford makes one of theseor I would source an electric pump that will keep my system @60PSI with the regulator just at the full open pointā¦
I think a steady 60 PSI gallery pressure would really help with the low RPM coal roll when I override the fuel ratio limiter to deal with a tailgaterā¦![]()
Well it would be the electric fuel pump and filter assembly used on the ford power stroke pickupsā¦What the Ford part?
So, if I understand:i wouldnāt āAddā a pump at the tank, I would replace the mechanical lift pump in the governor/HEUI assembly with a 60PSI feed pump and filter at the tank(All electric, no mechanical pump at all) Just so happens Ford makes one of theseor I would source an electric pump that will keep my system @60PSI with the regulator just at the full open pointā¦
Sort of. Remove separator primer all together, Install ford 60 PSI pump and filter module(has a filter and water/sediment drain on the bottom) from a 6.7l power-stroke, at tank to feed up to filter on engine.. connect fuel line from near tank pump up to input of filter on side of engine. Wire pump to ignition controlled power and enjoy your steady 60 PSI whenever the ignition is turned onSo, if I understand:
1ā move water fuel separator filter to the tankā easily viewed at every fuel fill and walk about;
2ā bypass mechanical lift (60 psi) pump at HEUI pump with electric 60 psi pump between water separator and primary filters.
Essentially removing one pump and repacing geared galley pump with steady electricā
