So I thought I’d jump in here to share what I did on my bobber.
I had read a post previously by one fellow that mounted the Hydromax unit under the cab, rearward from the factory master cylinder, but I can’t seem to find it now. His installation is the route I decided to go, for a few reasons.
So a little more info on my truck. I installed power steering using a steering box and components from a Canadian MLVW, and used a 5ton power steering pump to run it. Works excellent.
I also wanted dual circuit brakes though. I used Hydromax setup out of a ford b-series school bus, and mounted it underneath, with a remote reservoir. I also used stock brake pedal too, with my own made adjustable link to the hydromax unit. Part of the reason I didn’t mount it on the firewall is that I didn’t want to have a hanging pedal for the brakes and a through the floor pedal for the clutch.
Using the factory pedal gives me a lighter than stock pedal feel, but not too light. And man does it work well. Will easily lock up all four tires on pavement if needed. Brakes better than it ever did with the stock setup.
One advantage with using the stock pedal geometry is that I don’t need to have the auxiliary electric pressure pump hooked up, could prob remove it altogether, especially considering the expensive “cross” part required to rotate 90 degrees from stock configuration. Did a test, and with the engine off, I can still stop the truck, just requires a bit more effort.
Only things left to do now is fabricate a mount for the winch pto shifter, and mount a switch for the brake lights.
Here’s a few pics of the installed Hydromax.
