A very odd TRANS light issue
CallMeColt
1,633
Wilson County, Texas
Everyone,
I've been troubleshooting this one for a few weeks now & am going to make a nice, long detailed post.
Truck is a 1988 M1097R1 w/ A2 powertrain in it from it's 2012 rebuild.
The first obstical was putting a new TCM in the truck when I finally got it. If you want, read up on that one here as it had a similar issue, but that TCM was 100% hooked to 28v or higher power & burnt out;
https://www.steelsoldiers.com/threads/transmission-diagnostic-mode-issue-i-couldnt-find-here.221920/
After solving some other issues that came up, I went to go take the truck on a test drive. Got out on the highway, and it didn't get to 4th gear. Look down to a lovely TRANS light again!
Where I'm currently at.
-TRANS light is on solid when truck is running. Truck is acting like no 4th gear & no TCC lockup, but no code.
-Hooking up my SuperFlow Supershifter, it doesn't get past the power on screen. This is my only 4l80E truck, so I honestly don't know if it works & I just got it!
-It will go into diagnostics mode via jumper. Only gives a 12.
-TCM was installed from a sealed military foil wrapper 2025FEB07 this light came on 2025MAR30. I had put maybe 50 miles & a few hours on the truck.
-Has brand new batteries in it right now
-All grounds are clean & tight
-Confirmed the TRANS light is not a short. It will not come on if TCM J1 is disconnected.
-Spent significant time testing wires & circuits for test as the Supplement guide calls for. Have not found any bad wires, connectors yet. Truck overall is very clean.
-Speedometer (80mph electronic) was off & I changed to 41 tooth at the transfer case. It is spot on now. Wasn't sure this effected anything but needed to be done.
-Found the brake switch had a dead spot. Replaced (with a AM General part) & adjusted properly. Had previously adjusted it not realizing the dead spot was on the brake light side.
-Breaker & power relay are good. Confirmed power readings right at the connector that the TCM goes to, not TCM connector J1.
-Used DeoxitD5 on all connectors to be sure they're clean.
-Have tried removing the TCM & let it sit without power for a few days.
-Kascar supplemental grounding wire kit installed.
I'm sure I did more.
Here is a list of things that I'm thinking MAY had triggered the issue from least to worst.
-Transmission fluid was grossly overfilled when I got it Drained some out. It developed a leak when I got it out on it's first drive before this TCM issue came up. Went 80MPH no problem.
-When I adjusted the brake switch, I didn't realize the dead spot was on the brake light side & only was using the lights as the means to adjust it. This could (and probably) made it so the switch was triggering a MIL due to the switch being open. This could cause my symptoms but the issue should reset with a power cycle of the ignition.
-I had let the truck sit for a week. When I came to move it, batteries were weak. I attached a jumper pack & didn't disconnect the TCM. The reason for the no-start was not the weak batteries, the IP decided to get stuck closed. In my frustration with the situation, I tried cranking a few more times before disconnecting the TCM. However, I did not have any TRANS light issues until what I mentioned above.
-After getting home when the TRANS light came on, that is when I decided to just replace the batteries. They were only 3 yr old Hawkers that I revived that came with the truck BUT wanted to just get something new in there to eliminate a problem.... the batteries shouldn't have drained so maybe a cell was bad? When replacing the batteries... found the bolt for the main ground at the shunt was loose! I was mortified.
So, here is where my head is at right now with the issue, even though I don't want it to be. The loose ground was the issue. It could have caused voltage to travel back up a wire to the TCM or something like that? The grounds for the TCM were good & tight. Maybe power was "chattering" on & off to it as I was bumping down my county roads, similar to when you have really dead batteries & slave start? Could have "half baked" the TCM & it is stuck in a NO 4th NO TCC LOCKUP type fault that may have been triggered by my bad brake switch adjustment while it was getting hammered with a bad connection driving down the road?
I really would just light to find the root cause so I don't just toss a TCM in & end up with the issue again in 50-100 miles. I do have another, brand new one here but am reluctant to just toss it in.
Figured I'd come here to see if I missed something or get another idea as I'm frustrated with it. Got EVERYTHING else good. Well, I say that, & the starting issue is coming back again... kinda. But, that is not for this thread. The truck is super clean & worth the work for what I want it for. Engine has 0 blowby. Body is very clean. Once it's squared away, I plan to mount a very nice military radio system in it that I have.
Thunderbirds
425
Northern Black Hills South Dakota
Have you Ohm checked and voltage checked your throttle position sensor? If that doesn’t read correctly, it may not understand to shift into 4th and TCC. That was part of my problem anyway…
Best of luck, don’t throw the new TCM in until you have a definitive answer, IMHO.
CallMeColt
1,633
I didn't do the TPS but it was fine before all this & doesn't show signs of being moved. But, I should check it just to confirm. It won't hurt & it's a simple test. Don't think it would explain the TRANS light just being on either way. But who knows, this being so odd!
I'd love to have a definitive answer, but I'm thinking that I may not get one..... hope to prove myself wrong!
CallMeColt
1,633
If you had come here and just said “my trans lamp is on when Engine is running“ I would tell you you’re crank position sensor is bad or unplugged.
I did put it as #1 on my list! Pretty sure I tested that when I first got the truck, but I will ad that to the list to check again. Actually had gone back & read my previous post & it was suggested when I was eyeing the truck & made me think of it again. With everything going on, easy to forget the simple stuff.
