AllAmerican505
- 2
- 3
- Arizona
I just tested from the alt plug brown to build and has continuity.Just need to put your voltmeter in between and read what it says. Figure f9 in the tm shows the connection the brown wire goes through the firewall on. Back probing that is very difficult so you'd have to unbolt it to test it from the block to the alternator and the block to the bulb.
