hiding the winch
maddawg308
762
Appomattox, VA
I think you're going to have to put a fairlead roller on the rear in order for it to "feed" well, possibly a pulley system to reverse it and feed out toward the front if you want to go that route.
ARMYMAN30YearsPlus
Parkville, MD
That looks interesting kinda like a Russian truck I saw in Bosnia. Can you post more pictures of you bob? It looks like the driveline is not hooked up so how do you know it is faster than your wrecker?
rosco
30
Delta Junction, Alaska
I put a PTO winch back under where the spare tire would go, in one of my old International pickups. When using it, one has to be real careful about the line, that it doesn't become tangled. A set of fairleads for it is imparitive. If you have hydrolics availiable back there, not sure that you would need the PTO. Juts run things on the hydrolics.
Lee in Alaska
mlwats1@hotmail.com
carthage missouri
RE: fairlead view
i could put the brake lines on top and in front of the axle, thanks for the idea, and you are right i could put a winch pully at the rear and run the line forward if needed, i think a level wind is in order.
cruzinz28
Maryland
mlwats
Do you have any updated pictures of your install??? I would appreciate any that you have. I have rounded up all the parts to add a rear pto winch as well, excpet I plan to power the winch via a direct drive shaft. Hope to hear from you soon.
- Jesse
rosco
30
You'll want that fairlead turned upside down. Otherwise the line will just droop down (with gravity), and not be guided at all. As much as a Guy tries to keep the line straight off the drum, you always seem to have to pull at an angle!
