Ran before parked....
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
I always get a kick out of this. It's sort of along the lines of the "Ran when parked" story, but not exactly. I like when GL says "Unknown Running Condition" and then includes pics of the trucks freshly "windowed" block.:cookoo:
Of course, the first pic might explain the second. Who was responsible for the placement of THAT sticker???:shock:
Edit: It's a Cummins....
BKubu
1,164
Gaithersburg, MD
If any truck should be residue, that is the one! It is no wonder that they blew the motor up running it at such high RPM!
WillWagner
2,758
Monrovia, Ca.
2100 is the loaded governed speed. Unloaded governor break is around 2400 RPM. They will run and stay together up to 3000, but not for long periods of time. They get real quiet at that RPM:shock:
Monkeyboyarmy
194
Kingsville,Oh.
My buddy runs his Kenworth road tractor with a Cummins N14 (nearly the same bottom end as the 250 ) at 3500 when he is at the truck pulls.After a year of abuse,he'll pull the pan and check the bearings...always good.He does have stiffer valve springs and uses high quality racing oil in it though.Every time I drive my 816 I think about turning up the rpm.You just can't get going fast enough to catch the next gear with any momentum.
Capt.Marion
15
Atlanta, GA
Yep, that seems to be the deal with most MVs, closer gears and you'd be in hog heaven.
