CUCV Build... Here We Go Again...
Recovry4x4
LLM/Member 785
1,807
GA Mountains
You could keep that area open and use it as radiant heat? I bet you're sorry I ever bought that motor.
devilman96
17
Boca Raton, FL
It aint giving me one inch of easy thats for sure... I just keep sayin its worth it... its worth it....
the exhaust feed pipe will touch the floorboard on the drivers side, a 1" body lift should take care of it.
Naw I believe I've got it with this as I took out the pinch weld in the body in front of the gas petal mounting... I started on the body life thing and changed my mind... They look like total crap to be nice about it!!!
I'm taking this weekend off... I'm pretty beat up after the last few weeks of working non stop...
Also... Looks like Crash was able to cut out the roof corners of his parts truck so next week might be a good week with a LOT of this thing coming back together!!!! SWEET!!! I need to see some serious instant gratification about right now as I'm feeling pretty over whelmed about the deadline!
ONTOS66
Franklin, NJ
Wow! What a project! I'd ALMOST drive to Florida to see the finished project - but I HATE sand! 4 years in the Fleet Marine Force - and I NEVER want to see a beach again!!!
42 degrees and he's inside under the blankets? It was 18 degrees last night with a light snow and I had a Boy Scout troop and some silly civilians camping in tents and smiling. :)
Very impressed by the talent and deep pockets for a project like this. I'm doing good to finish a rattle can paint job for my M1028.
Recovry4x4
LLM/Member 785
1,807
GA Mountains
I live 15.4 miles from the beach and haven't been there in years unless friend come by and want to see! I love sand, despise the beach.
radar 12
dallas /ga
First time poster here. I believe iI have the od green bug - trying to score a 1009 from a private owner and i must say i think your resto/revamp is slick. What type of a/c setup will you use? I can retrofit a 1009 with gm factory parts but will lose the dual alt. and i don't want to pay a grand from vintage air.
dc3coyote
19
Chattanooga TN
The beach I love it. I actually run there every day..now that said. I REALLY hate the sand, but the scenerey is nice. ONTO your in luck the FL rally is held in central FL theres not much sand there just cow pastures and FL scrub brush.
I cant wait to see your new project Mike, and THANKS alot you got Brittany talking about me getting one for her to drive. Now her want list is bigger than mine.
mangus580
282
Western NY
devilman96
17
Boca Raton, FL
Have you used this kit before ? Quality parts?
Hi radar, OD Iron is me, or I am ODI... how ever you want to say that.
The kits are made specifically for CUCV's and retain the stock alternator set up. I am using one of these kits plus a rear unit added in as I know from installing several of these now that just the front set up "works" but like any modern SUV, due to size, it really takes two units to work "well"...
its important to keep in mind that AC does not cool air by passing it over a cooling fin... AC extracts heat from the cab air with the evaporator and relocates it outside of the vehicle via the condenser. I point this out because there is a limit to what any system is capable of doing based on ambient air temp, vehicle temp, etc, etc.
The kits do work... Insulating the cab makes them work a LOT better... Using R12 v/s using R134 makes them work 20-30% better. New door and window seals make them work even better... Filling the roof and pillars with expandable foam helps, rubber floor mats with insulation is a must... What I am getting at is how well the systems work is really up to how capable your truck is of having AC.
The install is a real... ummm... treat!!! It is not a one day job, even with experience. Plan for a whole weekend and a buddy to help keep your sanity. Because of what the truck is, never being designed to have AC, along with the amount of fitting needed it takes time... holes need to be drilled... lines crimped... parts need to be fitted, etc. Its impossible to sell a full bolt it kit as there are different configurations to these trucks so heed to my warning and mentally prep yourself!!!
Otherwise, yes they are quality... They do work... and they do hold up and if you have any issues (only had one problem with a condenser so far) the issue will get fixed!!
There is more info with pics in this thread... http://www.steelsoldiers.com/showthread.php?t=20944
As for this truck that I am currently working on with the dual system... The price tag is about 1800$ and the amount of work to do it is more than most people would ever be willing to do no matter how great it works...
Someone mentioned something about all of this costing a pretty penny... Yeah it does... but realistically guys its like my deuce was. I've been buying parts for this build for WELL over a YEAR now, stock piling them, plotting, planing, scrounging, etc, etc, etc. ODI doesn't generate enough cash to even think about coving this project (and I didn't have ODI when I built Diablo) Its my pocket that feels it... we make a lot of sacrifices around the house to make this happen, all cash, no credit cards involved... If you start by buying parts, then buying a truck, then buying the detailed stuff for the truck BEFORE taking the truck apart anyone can afford to do work like this when you spread it out over 16-18 months before even starting... then all it takes is time and dealing with the hiccups!!! and oh yeah... lots of Red Bull!! Like Kenny says.. "that stuff tastes like $hit but it does it's job" rofl
Updates... I installed one of the electric window motors today, pretty cool set up, I think I can adapt the motor to the rear window too!!! Also started sorting out the computer system... fun fun... pics tomorrow maybe!
Crash_AF
Colorado Springs, CO
Why not just get the electric tailgate window setup from a civilian Blazer instead of modifying something?
Later,
Joe
devilman96
17
Boca Raton, FL
A few reasons...
20+ year old parts... or a new reg, motor and switch is over $600.... None of which is the greatest in design ether.
I went through the effort of replacing the lower rear sheet metal in the tail gate with 10 ga steel (damn rust!)... So mine is pretty bullet proof and ain't getting swapped out.
I couldn't find a civi tail gate with in 200 miles of me if I wanted to! So I'd have to ship it in from somewhere... and a guarantee it will be rusted!
Honestly... I am so impressed with the way these motors work I think they would be far better than the stock set up is.
Mod'ing the exhisting takes work... Installing the civi take work... I trust my mods more so than the civi set up.
Later,
Joe
devilman96
17
Boca Raton, FL
OK some pics... Window motor installed, door lock also... I'm liking this set up!
Steering colum... completely dissembled, sand blasted, powder coated, switches all cleaned and lubed... ready to go back in.
The start on the computer... Micro ATX, 12V 360 watt power supply (designed for vehicle use), 500gb SATA drive (have 2), surround sound, HDMi video... all in a 11X11" foot print... Pretty sweet! It will have a full 8 gigs of RAM when installed, one terabyte of writable drive and will control almost everything in the truck. Should be pretty mind bending!
I also up'ed the anty so to speak and got a wireless router designed for broadband cards... When installed anyone with WiFi can use their computer inside or near the truck... It will be nice for the rally, kids, etc!!!
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Great Mike, now Mang is gonna need to change his shorts and have a cigarette!
devilman96
17
Boca Raton, FL
Yeah I know... thats why the exhaust is going to be a stack up the side like a deuce, not a tail pipe with in his reach!!! We would have to spray him with a hose like a dog!!! rofl
Ditto to Gimpy. Mike your gonna have to limit his time near your truck. Man
I cant wait to see it.
Im looking into vehicle tazer systems!!!
I dont need him... My new cell phone has its own built in wifi router :)
Is it mud proof? LOL
radar 12
dallas /ga
Thanks for the info DM . If I can get the guy to email me back , i want to go look at or even pick-up the 1009 this weekend if it's not cancer stricken too bad. frustrating:evil:
devilman96
17
Boca Raton, FL
Well here is a little slice of hell for anyone thinking about putting a 6.5 M998 engine into your CUCV!!! I took a LOT of pics, for those interested I'm sure they will get starred at for a while, ya kinda have to to comprehend the mess!
As you can see the heater box is done... Easy job!
The tunnel is getting smaller and smaller as I work on it, more angles will get added but I went very over sized compared to what HAD to be there... The idea was I can still get to the back of the engine to work on it without having to yank the out later on... IE you can get a ratchet on the back of the turbo, exhaust clamps, etc.
I'm still working on the driver side.... that gas petal mounting area is a lot of fun but its coming!
Finally got my engine parts in today!!!! Be nice to fire that up again over the weekend.
