JC
- 0
- 1
- Crofton, MD
SOLD!! Thanks.
I went out this morning to start my CUCV to go to work and I'm pretty sure I burned out my starter. Instead of replacing the starter (which I did last year), I'm going to sell it. $500 and it yours. You will need to tow it.
I bought the truck about 3 years ago and it has been my daily driver ever since then. Since I've owned it I've replaced the water pump, the glow plug relay, the glow plugs, the temp sensor, installed a cigarette lighter, replaced the hood, the tail gate handle and the batteries. I'm sure I've done other things to it but I can't remember them right now.
The truck was running and used as my daily driver until this morning. If you replace the starter (I think it's the bendix spring) it should start. The truck has been giving me problems starting in the morning so I think it needs a new control card or you could install a manual override button. Also the passenger side rocker is rusted and needs replaced. The drivers side rocker was patched over by the military but there is still some rust around the edges of the patch. There is rust in other spots inside the truck as well. The drivers side alternater may need to be replaced- the Gen 1 light has been coming on faintly and the volt meter is right at the yellow and green line. It is in the green if the headlights are not on. It also pulls to the side when I brake hard.
The truck has a strong engine. I have a friend who has owned about 10 CUCV's and he said it has more power than any of his trucks. Until today, I was driving this blazer about 30 miles round trip Monday - Friday to work on a major highway (Rt. 50) where the speed limit is 65.
I've attached some pictures. If interested contact Jim at 240-988-1829.
