OD_Coyote
- 58
- 28
- North Bend, WA
Did anyone here win the (3) M35A2Cs in Ft. Lewis on the GL site?
MilitaryRestoration got one of the 818's, ask himSaw those, I was going for the 818's.
Curious to see what they went for though.
Wow! That was more then all but one of the 818's!They ended up selling for 3700-4000 each (not including taxes or GL fees)....no thanks
WSUCUGARX we bought the 9k mile oneJust and FYI on those M35A2C's from FT Lewis. I inspected all three trucks and I did start them to make sure they would start. There were three trucks a 4k mile one, 9k miles one and a 11k miles one. (all are "C" engines w/whistlers)
The 4k has absolutely no brake pressure, pedal goes all the way to the floor. J-pipe is rusted all the way through, batteries are dead, most of the driveshaft seals are leaking as well as fluid leaking out of the pressure caps on axles, transfer case oil is pretty dirty. There is oil all over the driver side of the engine (loose oil filter canister? head gasket?
The 9k one has extra bows under the bed, good brakes, starts and drives, j-pipe rusted all the way through, spare tire is crap, oil in tranny is emusified (drain/fill before driving)
The 11k one has an extra set of bows as well under bed. No freeplay in brakes or clutch. Clutch engages about on the last 1-1.5". Definately needs adjustment. Noticed oil all over the driver side of motor also. Truck does run/drive
My bad you bought the ones with the fenders, if I am not mistaken. We bought the one without the fenderswiggall,
You said you got 2 of the 2 1/2 ton trailers? We got one and I thought that there was only two up for bid?
