KaiserM109
- 4
- 0
- SE Aurora, CO
I know, RTFM. The trouble is that I don't know what TM to look in. Here's the problem in a nutshell (coconut sized):
The deuce is a '66 Kaiser Jeep with a NON-turbo Continental w/ 23K miles.
1. It used to start easily until I ran it out of fuel and had to bleed air out of the valve at the top of the fuel filters to get it to start at all. After that it took longer to crank than before, but would start after about 30 seconds of cranking. It has been a storage queen and has only made a few trips around the storage yard because I don't have it insured and licensed. The fuel heater had a minor leak.
2. This past month it got down to 10 below zero and I went out to start it. It turned over, but wouldn't fire. I noticed the fuel heater was no longer leaking. I gave up, fearing that if I ran the batteries flat, they would freeze.
3. I came back on New Years Day with a helper when it was about 30 degrees. While my helper cranked it I opened the valve on the top of fuel filters, but nothing came out. Without cranking it, I opened each of the 2 valves at the bottom and got a slow dribble of fuel, no water.
4. Thinking that the low fuel level might be below the pickup, I added 5 gal. which brought the gauge up to 1/4. No change and using the heater, even though it is not terribly cold, did nothing and it didn't leak like it had a couple of months earlier.
5. I disconnected the low pressure alarm so that I could hear, turned on the accessory switch and listened for the fuel pump. QUESTION: Can you hear the pump when it is working? I didn't hear anything, even with the fill cap off.
Before I start disconnecting lines, I thought I should ask for a little advice.
QUESTION: Is there a more positive way of testing the pump's pressure? Considering that this might be a high failure item, maybe I should replace it and have a spare? What do you folks out there think?
Arlyn
Arlyn
