Help me build the ulitmate Deuce Recovery List with Instructions
BimmerPower
Banned
101
Mystic, CT
Hello all. First off let me start off by saying that I have been reading these forums for some weeks now and am amazing by how much information there is on here. I just recently won a GL auction for an M35A2 in great condition here in RI and plan on picking it up as soon as my EUC clears. Since I find myself checking constantly clicking on the GL site and refresh page here on steel soldiers every 10 minutes, I figure I'd like to do something a little more production with my time.
I find that there is a lot of information on these forums but that even with using the Search function, everything is scattered and relatively had to find. What I would like to is kind of organize some general information for not only myself, but for others as well. I think that it would be a great learning experience for me, we would all come up with a nice printable PDF (that I would make) and it would cut down on some of the newbie posts.
The first list I would like to start on is a Recovery manual that states what to bring (ie. items on the great list) and how much/how to get the vehicle ready for recovery. I would like to include in each category what type of fluid/lubrication to use and how much is needed. When everyone says top off all fluids, which fluids and where. Here are the topics I would like to cover:
- Engine Oil
- Transmission
- Axles
- Air System
- Differentials
- Brakes
- Transfer Case
- Stearing Gear
Side Notes for:
- Oil Filter
- Fuel Filter
- Fuel Additives
- Oil Additives (Diesel Kleen/Diesel 911)
What do you all think? I'd like to include pictures as well for a "Recovery for Dummies" manual. Cheers!
** I've edited the original post and am placing the work in progress here. Edits, additions and modifications will be made frequently and when needed:
Oil/Engine Lubrication
- 1 Case of 15/40 Engine Oil
- Slick 50 Turbo Formula
- 5 Gallon Pale of GL-1 or GL-5 Gear Oil good for Yellow Metal (Napa # SUS52)
- Engine Oil Filter (Napa # 1133)
- Oil Filter Gasket (Napa # 5119)
- Grease gun for chasis lub with extra tubes
- Pump for GL-1 Gear Oil
**For Synthetic use**
- **Amsoil 15w40 Diesel Marine Oil**
- **Amsoil 80w90 diff oil (reg) for diffs, transmission and transfer case**
- **Amsoil Synthetic Grease**
Lubrication Notes:
- Add Slick 50 to oil before cranking to aid turbo lubrication
- Check Transmission Oil - When filling the transmission with the side plug, fill until the fluid goes to the first knuckle on your index finger. Don't actually fill-to-spill or it will be slightly over-serviced.
- Check Transfer Case Oil - Knuckle fill appropriately with GL-1
- Check Differential Oil - Knuckle fill appropriately with GL-1
- Drain and refill transmission, differentials and transfer case as soon as recovery is complete
Cooling System:
- 2 Gallons Anti-Freeze
- Distilled Water
- Radiator Cap (Napa # 703-1422)
- Thermostat (Multi-fuel Napa # 358-180)
Air System
- Air Filter (Napa # 2837)
- Alcohol/Methanol
Air System Notes:
- Open air tanks and remove water and crud from system.
- Air Compressors: One is a single cylinder, the round one (Midland). The other is a two cylinder that looks like a figure 8 (Bendix). Both are air cooled.
- Taken from Cleb on SS: On the airpack, frame side, there is an airline coming in, that goes to a flange, which is held to the airpack by 4 bolts. I had a slight air leak I could feel around that area (only held about 60psi running). After tightening the four bolts equally, the leak went away. They are a bit hard to get to, patience is your friend. Taking the skid plate off will also help. The air seemed to be coming from the actual fitting the copper line went into, but it was really the flange leaking that made it seem that way. One other thing to check are the drain valves on the tanks. Mine were leaking slightly. After fixing those 2 things on my truck, she will hold 60-90psi overnight no problem.
- Taken from Racky on SS: Check air compressor belt condition and tension. If all is good take the black cap off the regulator and you will see a screw with a lock nut. Loosen lock nut and turn screw in 1/8th turn if pressure doesn't come up it could either be a partially clogged air screen on the regulator, a faulty regulator or a compressor on its way out. The truck should hold air overnight.
- Taken from Barrman on SS: The air compressor has something called "unloader valves." The air from the regulator on the firewall opens these valves and makes the compressor not compress. When the regulator decides the system needs more air, it removes the air from the valves and the compressor starts pumping again. Start simple when troubleshooting: Remove the intake screen/filter on the compressor and make sure it isn't plugged up. Still no workie, then start looking at the unloader valves. They are basically held down by a spring. Pull the cover off and check out the springs. My Gasser had one of the two springs broken off just a little at the end of the coil. I put a washer in as a shim and have had 110 psi air ever since. If the unloaders check out ok, then you need to start thinking about rings. However, first pull the output line from the compressor, fire up the truck and see if it is pumping air now. You could have a plugged up line somewhere between the compressor and the tanks. No air out means no air in.
- Taken from Barrman on SS: Another way to keep air in the system without running the engine is to use the emergency glad hand on the passenger side rear. Put fittings on it so you plug an air hose from your home compressor to the glad hand, open the valve and crawl under the truck to find the leak.
- The air compressor is lubricated with engine oil. There are oil galleys on the compressor and the engine and pressurized oil from the pump is sent to the compressor and out of it back to the sump.
- The air system check valve is the big round thing in the line that connects your two tanks together.
Brake System
- 2 Quarts DOT 3 AND DOT 5 Brake Fluid
Brake System Notes:
- Check Master Cylinder Fluid Level and top off brake fluid if necessary
- Open the little plate on the driver side floor board and you will see the cap and the breather line on the brake system
- When mixed dot5 and dot3 make a thick goo at the bottom of the Master Cylinder. It will clog the lines and destroy the seals on the wheel cylinders if it makes it that far. Silicone is purple (at least the new stuff is) if you put some of the fluid in question in a jar with a few drops of water and shake it up a lot, dot5 will not mix with the water. Dot3 will.
- DOT 3, 4, and 5.1 can be mixed if necessary, according to the instructions on the cans. DOT 5 and DOT 5.1 are not the same. DOT 5 is a silicone based fluid, and DOT 3, 4, and 5.1 are glycol based. There are two types. The first one is regular auto brake fluid. The second type is Silicone-based brake fluid. You can not mix the two types of fluid (well, you can, but you will end up with a jelly-like mess). You need to find out which you have already in the system. Here's how:
1. Get a dropper (an eye or ear-dropper) and withdraw some fluid from the master cylinder.
2. Put it into a glass jar and then add some clean water to the fluid.
3. Now put the lid on the jar and shake it well.
4. Let it stand for a few minutes.
5. If the water and the fluid have mixed thoroughly and can not be separately identified, then you have regular auto brake fluid.
6. However, if the water and the fluid have not mixed, or have formed blobs or layers, then the fluid is Silicone.
Electrical System
- Two Optima Yellow Top Batteries
- Battery Terminals
- Napa Light Bulbs (Front & Rear Parking # 623, Turn # 1683, Headlight # 4863, Instrument # 1829)
Fuel System
- 10 Gallons of Premium Diesel Fuel
- Diesel 911 or Diesel Kleen Fuel Additive
- Fuel Filters (Primary Napa # 3511, (2 total) Secondary Napa # 3540 Gold)
- Fuel Filter Gasket (Primary Napa # 5131 Secondary # 5070)
- Piece of wood to place in front of air intake in case of a runaway motor
Fuel System Notes:
-Line Cleaning: 1) Remove fuel line from tank 2) Open water separator 3) Remove secondary and final filter, clean bosses 4) Blow fuel line back towards tank 5) Re-Install fuel line
- If it is a multi-fuel there is a bleeder nut on top of the secondary and final fuel filter assembly to help bleed the system. It is on the left side of the engine near the firewall. Since it has a tank pump, the fuel will go from the tank and flow through the primary, secondary and then final fuel filter. Do this with the master switch on. When you see fuel coming out of the bleeder system, it is bled up to that point. Retighten bleeder screw. Go back and hold throttle wide open and crank. The cylinders will fire one to two at a time. Back off throttle a little at a time till vehicle smooths out. Avoid revving engine past 1000rpms. After a couple minutes of idling it should be OK. Be ready with a piece of wood to place in front of air intake (to cut-off air supply and emergency stop engine) in case of a runaway motor.
- The fuel line comes up at the fuel filter closest to the firewall. One can gain easy access to it from topside.
- The primary fuel filter is also a water separator. The primary filter rides on the spring. The bottom half of the canister is used to catch any water in the system.
- Location: The primary fuel filter (Napa # 3511) is by itself under the alternator. Both secondary (Napa # 3540) are on the driver's side of the motor block behind the oil cooler.
Engine
- Compressor Belt - (Napa # 25-9510, Good Year # 17511, Gates # 9510)
- Alternator Belt (2 needed) - (Napa # 25-9470)
- Auto clutch return springs ( in case throttle linkage is loose)
Engine Notes:
- There are only 3 belts on the M35A2. One for the air compressor and two (a matched set) for the generator.
Tools/Items To Bring
- Air Compressor
- Air Pressure Gauge
- Air nozzle with tube attachment and tire inflator
- Complete Mechanics Socket and Rachet Set
- Allen Wrenches (9/16 for transfer case)
- Various hand tools
- Generator
- Various funnels
- 2" Pipe Wrench
- Rags/Paper Towels
- Tow Bar
tamangel
19
Nor Cal Coast
here's a 'Recovery List' from the old Forum..
http://old.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=143 edit: looks like the same info/post below from the new forum..
Mike
also the FAQ on deuces: **
http://www.steelsoldiers.com/forumdisplay.php?f=20 then click on "Deuce FAQ Article"
** couldn't post the direct link to the Deuce FAQ page as the URL contains 'colon D' which comes out as the emoticon for 'grining' :D , therefore making the link un-transferable when posted like this: (the pasted URL when I go to 'edit' shows as '=wiki colon deuce-you can see that it doesn't show like that here..) http://www.steelsoldiers.com/showwiki.php?title=wiki:Deuce ...funny...
tsmall07
Springfield, VA
I think this is a really good idea. Any chance you could get the recovery manual in about 3 weeks? :-D That's when I'll be picking up my truck.
One thing that would really help me out is the capacities of each system. Everyone says to bring oil, brake fluid, and what not, but I don't really know how much to bring (especially the brake fluid). I think a 5 gal pail of oil is ok, but I don't know how much gear oil to bring. A description of the drain/fill plugs would help, too. I'm sure I could figure it out when I get to the truck but I would like to know ahead of time.
Tyler
Edit:
Here is the "Great List" on the new forum.
http://www.steelsoldiers.com/showthread.php?t=133
I guess that has the amounts that I need.
BimmerPower
Banned
101
Mystic, CT
Well I started so far but am debating finishing or not. Can anyone who is familiar with recoveries look at what I have and check it out for errors? Thanks.
PR
Note that this Recovery is intended for the M35A2 Duece.
jimm1009
71
Louisville, KY
oil capacities, etc.
Go to the resources section on this S.S. site.
Scroll to LO 9-2320-209-12-1, right click on it and then left click on save as.
Save it to your desk top or where ever you are wanting to store it.
It has all the capacities of the gearboxes, engine, etc. plus the grease points and other useful information.
If you can't down load it I can send you a disc (CD or DVD) with the manuals on it.
98% of the manuals that you need (or more) are here on this site.
It's faster to right click and then save as over just opening and viewing.
Ask if you need help.
Attached to this post is one page from the Lo (Lube Order) just so you can see what you need.
Good luck.
Jim
jimm1009
71
Louisville, KY
Deuce oils
Shell Rotella-T is an excellent oil for the engine.
NAPA sells the GL-5 oil in 5 gallon pails.
See the picture of the pail here in this post.
I would take 2 gallons of engine oil and one pail of geargox oil.
Three axles, trannmission, & transfer case all take the same oil.
What ever gear oil you choose, you MUST make sure that it is "yellow metal compatible" as is the example pictured here.
GL-1 was the original oil and some prefer it but the newer oil due to later technology is GL-5.
Take a grease gun with one fresh tube of good grease for the drive shafts an dobviously rags, misc. tools, jack 8 ton or better, etc.
Other will chime in too but there is a Sticky for recovery listed here on the site too. Oh yes, & DOT-5 brake fluid (not DOT-5.1).
All gearboxes get filled to where your index finger will just get wet when inserted in the fill-hole to the first joint of the finger. Fill-to-spill was the original intention, but has been revised over the years.
AndrewH
Boyne City MI
Lug nuts.
I have only gone on a few recoveries so far but every time I have had loose lug nuts. An M35A2 at selfridge. need a 13/16 square drive and a 1-1/2 inch socket. I have had good luck getting all the rears by loosening the outer and tightining the inner three at a time to avoid removing the outer wheel. Saves jacking the truck up. Remember right hand and left hand threads. A 3/4 ton trailer in lansing loose lugs. tanker in gaylord, loose again. My 2 cents!
Michael
24
Fulton, MS
NAPA is not the place to buy headlights. They wanted 150 the last time I checked and you can get them from MV dealers for 20 to 25. It has been years since I bought one though, so if these numbers are no longer correct please feel free to correct them.
crazyplowboy
Champion, Ohio
Your numbers are correct, my local NAPA wanted $165.95 per bulb and it would take a few weeks to get them in. I ordered from Saturn Surplus for $26.50 per bulb, and they arrived in about 3 days.
Michael
24
Fulton, MS
Did you get import or US made bulbs from Saturn? I ordered some from somewhere a long time ago and got import, lasted about 10 mins. when I finally got around to using them.
Jinx
Buy me a Coke
161
Gainesville, Florida
Excuse me for bumping an old thread, but it pertains to my question.
My rear brake/turn signal bulb is burned out. I would need to go to NAPA and order bulb #1683. Is that correct, or would it be #623?
