Frame size?
gringeltaube
Staff Member
2,518
Montevideo/Uruguay
Does anyone have the frame sizes of a 5 ton and deuce handy? Height, web size and thickness? Thanks
Deuce frame U-channel:
Legs O.D. ("flanges") = 3"
Web Width (height) O.D. = 8"
Thickness = 5/16"
5-ton frame U-channel: (Courtesy of Chief1900)
Legs: 3"
Web: 9"
Thickness: 5/16"
Tks
G.
yeager1
Colorado
thought it sounded a little short?
Couldn't agree more. If the 2.5 ton is 8 x 3 by 5/16" I would be very surprised if the 5 ton was 9 x 3 by 5/16".
Does anyone have the dims? or maybe a truck to measure? :-D
mtk
Finleyville, PA
The thread about 53's has some close-ups in it that show the frame rails.
They're WAY larger than 9" as I see it. More like 12" or so.
USMC6062
St Augustine, FL
It looks the same in width and thickness, as a deuce frame. I would measure it tomorrow, but I'm going out of town for 10 days. I'll try when I get back if no one else has by then.
yeager1
Colorado
Thanks for the info. I'm just surprised that the deuce and 5 ton are so close in size (and strength), especially when you factor in that the standard 5 ton is considerably longer.
davesgmc
131
Mclouth, KS
my bridge truck has a section of frame through the middle that is 12 inches tall, it is riveted to the original 9 inch tall frame, factory.
was told this is because of the extra long wheel base.
jasonjc
289
Gravette Ar.
The XLWB Deuce also has a frame dubbler on it. It is a "L" riveted to the frame. Seems like a bad idea to me. Its open at the top but closed at the bottom and makes for a good(bad) place for water to collect.
