- 10,859
- 746
- Front Royal, VA
Been a while since I took these pics, but I thought I would share them. In September, I got all the parts together for a winch install on my deuce. I bought Builder77's winch off of him 3 days before he died ( ), follow up bad news to that story is his winch leaks like a sieve, and needs all the bearings and seals re-done. Until I can get that done, I wanted to install the winch brackets anyways, mainly to get the higher bumper, and a meaner look.
Taking the bumper off for the winch bracket install was a pain in the a s s. All the bolts holding the bumper on were rusted solid, my homeowner's size compressor and 1/2 inch impact wouldn't budge them. I had to remove all of them by hand, with 1/2 inch breaker bars and socket sets. Took all day. The previous mechanic used Grade 1 bolts to put the bumper on - not sure why. Anyways, the bolt set for installing the winch brackets and flipping the winch cost over $100 just for the Grade 8 bolts, nuts and washers. I used stainless washers, I didn't see a need for Grade 8 washers, and I try to use stainless whenever possible to prevent future corrosion. If I have to replace hardware, I only want to replace it once.
Hope you all like the mod I made with the, uh, front end cargo. It turns a lot of heads! Even the local officers get a giggle!
