KsM715
- 142
- 63
- St George Ks
Still waiting on the EUC, but in the mean time Im trying to gather up the stuff I need to take. StreetBikeDepot went and looked over the truck for me and sounds like I should be able to drive it home if the brakes work. Those didnt get checked specifically but there are no obvious signs that they have been leaking or anything so Im bringing some DOT 5 with me just in case. I have found all the napa #'s for belts and extra lamps and fuel filter numbers. On the cross reference chart on the old site there is 2 different #'s for the water pump belts, anyone know which is correct? 2522425 or 25-24438? Im gonna bring 2 new batteries.
The questions I cant find the answers to are: upper and lower radiator hoses numbers. I can not figure out what engine oil to bring? I was told the power steering pump was dry from a leaking steering box, I know the pump uses engine oil but I dont know what weight. I also want to take some gear oil for the axles but I cant realy tell from the TM's and lube orders what specifically it is either. I just read GO 80/90. is that just regular 80/90wt like you would use in the axles of a standard pickup?
any help is greatly appreciated
Jeff
Jeff
