Anti-Theft System Suggestions?
Recovry4x4
LLM/Member 785
1,807
GA Mountains
One other measure is to build a locking gate to secure the transfer case in neutral. I also rigged a padlock on mt E-brake handle stop curious folk from unlocking the brake.
scooter01922
42
Newbury, MA
Well that works. Where does the bottom of that angle iron attach, bend it a bit and use the 2 rear bolts that hold the thing to the floor?
BEASTMASTER
142
Burgaw, N.C.
you can lock the doors or i use a small piece of chain around the door handle and to the grab handle with a padlock. keeps the kids out. if someone really wants it they WILL take it.
BMCUSNAVY
Oak Harbor/Wa.
How do I post a thread....
I have read & read.... someone please break it down to elemantery..... and tell me how too post a new thread on this forum........ Thanks.......
wsucougarx
65
Washington State
My '86 has 4 antitheft features that came with the truck (San Diego deuce, naturally needs it:razz:)
1) The old chain around the steering wheel bit w/lock
2) Keyed ignition switch in place of the accessory switch lever
3) Floor mounted transfter case lock out bracket w/lock (keeps transfer case locked in neutral)
4) Fuel cutoff lever has a lockout tab w/small lock to keep fuel shutoff
Also, the fuel cap has a lockout on it as well. This truck is FT Knox'd:p
tm america
24
merrillville in
bmcusnavy just click on forum then look for the forum that most closely matches what you want to post click on it and near the top you'll see new thread click on it then you can start a new thread
Militoy
Mojave Desert, CA
The transfer lock is the same method I have used for years to lock up my Gama Goat. It was still stolen out of my front yard a few years ago by some very determined tweakers with a pair of bolt cutters - so I have since added a few other deterrents. I have a hidden relay that adds an interlock to the starter circuit - in order to turn the starter over, you need to push the start button - AND the horn button at the same time. For times when I'm parked overnight in a public area, I have a hidden manual fuel shut-off valve. Based on your photos - I'm now thinking of rigging an E-brake lock as well.
After my truck was stolen and recovered, it took several years to fix all the damage and get it back on the road. There was some difficulty locating a few hard-to-get parts - but even though Deuce parts are a little easier to source than Goat parts - who needs the hassle?! Extra security ain't a bad idea.
gerrykan
SGF, MO
I have a hidden relay that adds an interlock to the starter circuit - in order to turn the starter over, you need to push the start button - AND the horn button at the same time. I have a hidden manual fuel shut-off valve. Extra security ain't a bad idea.
The best security measure might be to not announce your security measures over the World-Wide-Web.
Militoy
Mojave Desert, CA
Umm - very good thought - but then again, there might be a few additional steps that need to be taken to avoid setting off a few security measures that I forgot to mention. This "ain't my first rodeo".
Chinookpilot77
Enterprise, AL
I know once I get my deuce I'm just going to install a butterfly valve on the fuel line under the truck...just like old school motorcycles. Very simple, and it'll do the trick nicely.
