Which Trailer for a Shop?
jime
Centerburg, OH
I've got a need for a small, mobile shop...workbench, drill press, small lathe, etc. I'd like to pull it with the deuce. What do you guys recommend? I've thought about some sort of "slide-in" for the bed, but think the trailer would work best. Jim
cruz
Racine/Wisconsin
what about a m146 trailer, you would need a dolly, but I think it would work out well, and they aren't very expensive, and are fairly light
319
Lieutenant
58
Michigan
I like the M146, lots of room. Also, they seem to be plenitful, and Like Cruz says, very inexpensive.
jime
Centerburg, OH
I was gonna get a m105 anyway, but I was worried about it being big enough for the shop.
If I get the m146...maybe I need a tractor to pull it ! :wink:
dm22630
42
Front Royal, VA 22630
You wont even feel the M105 behind you.
A tow dolly alone is going to weigh as much as the 105....then add on the semi trailer & extra wind resistance. You will be sorry unless you like driving 30mph.
2cents
jime
Centerburg, OH
You guys aren't making this easy! Currently, I'd only have to pull the thing 20 miles.
Really though, I know a lot more than I did a couple of hours ago!
m16ty
211
Dickson,TN
M105 trailers are fine trailers but there ain't no way you're going to fit a lathe, workbench, drill press, and toolbox in there and have enough room to use the equipment.
A M22 trailer might work but it's still a little on the small side and rare. A M349 Trailer weighs about 8,000lbs empty and is about 24' long but you'd need a dolly for this also.
You may end up having to look for something in the civilain world.
m16ty
211
Dickson,TN
Find a M109 that has been parted out. Use the frame and rear axles and body.
Put a pintle hitch on the frame and pull with a deuce.
The 109 body was made to be a mobile shop.
Just my two centavos worth.
wreckerman has a good idea :-D.
maddawg308
746
Front Royal, VA
There are some surplus M1061 flatbed trailers coming up for auction - they have 12-14 foot beds on them. Might be a good compromise between a cramped M105 trailer, and a semi.
A deuce can handle pulling it, although a little slow on the hills.
Mike_Pop
NJ
To add to maddawg's comment:
You can easily put an S280 shelter on an M1061 trailer and have something that you can actually stand up in. Plenty of room for tools.
The weight of the entire setup might be a bit much if you plan on climbing hills.
