bbqfan5909
- 0
- 0
- Euless, TX
My steering wheel is not straight, any suggestions to fix this problem? Great site, already fixed the hard shifts because of SS!
Carefull taking it to a shop. of course go there for alignment, but as far as centering your steering wheel, that can be done easily on your own as described above. I took my truck to a trusted shop (had their own racing team) for an alignment. I just installed new Tie Rod ends so I told them that I needed the ends of the tierods cut so that they could be closer together to canter the steering wheel. Idiot at the shop just backed the tie rods out, so I had and extra turn to the left and one less to the right. It caused the wheel to rub on the pitmanarm/Tierod end. I couldn't even turn out of the shop. I showed the guy and was told "well don't turn it so sharp that's how it is" spent the next 45 minutes at home fixing what i just paid $60 to have done with my alignment... I had no wandering in the steering and had perfect tread wear with the tires. Adjusting the Tierods will not change anything with toe or camber, just adjusts your steering wheel.This would require an alignment. You could mess with it but you are just guessing. I just paid $46 to have my car aligned at Belle Tire. Tell them the wheel is not straight and they can adjust the toe to get it straight. Basically, your toe in might be right so you need to make sure they know that you want the wheel to be straight. You need to pick the right place for the adjustment or you will mess up the toe. If you mess up the toe your steering will feel loose and you will start wearing tires out quick. Let a professional handle it.
Tie rods are the only way to adjust toe. Camber is adjusted by shimming or adjusting cams and caster is adjusted the same way as camber. I am not trying get into a flame match with you but I used to be a certifed mechanic. Toe is the difference between the distance between the tire in the front and the rear of the tire. If you don't think tie rod adjustment will effect toe then how do you think toe is adjusted on the cucv? Also, I know tie rod adjustments will not change camber or caster. Especially on a cucv. You would need a cutting tool and welder to adjust Camber or Castor on the cucv. Also, I agree that finding a good shop is tough but in the area of alignments a cucv is about the easiest truck to align since it only requires adjustment to the toe. I think you picked your shop poorly. I only call you out since you directly disputed my statement. If we still disagree then we disagree. Since we had this disagreement I went out and got the diagrams to illustrate.Adjusting the Tierods will not change anything with toe or camber, just adjusts your steering wheel.
For an experience person doing it I say you are right but if someone does not know what they are doing then they should leave it alone for the reason I stated. If he adjusts the wrong rod then he will mess up the toe. At any rate I gave him enough information to do it himself if he so chooses. I have just seen some people that did not know what they are doing mess stuff up really bad by just trying to do what someone told them to do. I helped a guy out one time with a Mustang with a 2.3 engine. He had his buddy helping him as the car would not start but would turn over. No fire. The put on on new distributor and other little items before my wife asked me to look at it. As soon as I asked him to start it I could tell it was not cranking right. I suspected a broken timing belt and took a peak under the cover and that is exactly what it was. I then had to fix it for them. The moral to this story is not everyone has your or my level of mechanical expertise. What is very simple or easy for me and you may not be for the next guy.Mine is currently off since I changed the drag link and didn't have time to adjust it, and I haven't found the time in the last week or so. It's easy to adjust.
I don't know why the hell anybody would pay actual money for an alignment in these (or any other solid-axle applications) trucks. The ONLY adjustment available is toe in/out, which is easily set with a tape measure, and is just like adjusting the drag link. Loosen two bolts, crank the sleeve thing back and fourth to achieve desired settings.
If the order is right, the first picture is of the connecting rod and the second should be the actual tie rod. The steering wheel can be adjusted with the connecting rod.
