Blood_of_Tyrants
- 10
- 38
- Lebanon, TN
You are doing it the hard way. Get two 6" timbers about 2 feet longer than the diameter of the wheel and chain it to the holes in the rim. Then just drive out.
Was going too.. Not enough chain, and it needs out now.You are doing it the hard way. Get two 6" timbers about 2 feet longer than the diameter of the wheel and chain it to the holes in the rim. Then just drive out.
I sure hope so !You've got a lot of extra weight being thrown in all directions with mud on everything. I'd give it a good pressure-washing before you worry about funky steering. I'd be willing to bet that everything will be back to normal once all the junk is off of it.
Don't know why it was so soft, it was never tilled there, and I looked, no oldOK ... I have to ask the question .. why is it so soft where you were driving .. The thing that comes to my mind is when I screwed up while clearing up about 30 long pines that went down in Hurricane Fran several years ago I discovered where the septic drain fields were by sinking a farm tractor into them.
I hope you didn't "find anything" like I did.
Nice job gettin her out though.
I already told her I'm buying a five ton.This is the perfect excuse that you need to present to the wifey, why you need a second deuce...... yeahhhhhh..... Incase one gets stuck, you have the other to help get the other out....... see my madness or should I say excuse..... It works. I have a 72 & an 83. Now I need the winches for both.....
