wait to start light
bryab123
Bristol, TN
what controls the wait to start light on my m1008? my light doesnt stay on as long as it should. i have found out the truck starts better if i wait about 5-10 seconts after the light goes out. i would like to fix the light to stay on longer
tourdog
madison me
The best thing to do is like I did is put a small little light on the glow plug side of relay so when the relay itself shuts off thats when i try to start the truck .I always always cycle twice maybe thee times in real cold weather starts every time .
mangus580
282
Western NY
If your truck wont start when the wait light goes off, your GP system is not up to snuff. I would suspect like jwaller says... you have failed plugs.
I have never had to wait any longer than the light (routinely dont even wait that long) even in 5 degree weather.
Certainly have never had to cycle them twice.
lavarok
33
Fellsmere, FL
I too am curious what controls the actual "ON" time. I have one '86 m1009 where the light is on for maybe 3 secs and a 2nd '86 m1009 where the light stays on for 8-10. Is it time controlled in the GP circuit board or is there a sensor reading that determines when it shuts off or cycles?
Inquiring minds want to know!
doghead
4 Star General /Moderator
1,179
A look at the Glow Plug Schematic, will show you that there is a "voltage sense wire" supplied to the GP controller card.
lavarok
33
Fellsmere, FL
Does anyone have the schematic for the card itself? I seem to recall seeing it somewhere, but can not find it now aua
That will clear up my question pronto.
1stDeuce
15
Farmington, NM
I don't pay much attention to the light... I use the volt meter as my indication for when to crank... When the needle pops up (and you can hear the relay kick out) I crank. The light in my truck wants me to wait a few more seconds, but w/o voltage hitting them, the glows are cooling during that time, so it doesn't make sense to me. You can see them cycle via the voltage...
C
