1400R20 on 900R20 Wheels?
HECKLER
Saraland Alabama
On my M35A2 I have the Michelin 1100R20 Super Singles. My question is what other tires could I put on the stock wheels like 1400R20? Because I can't seem to find any 1100R20 tires
Westech
CPL
6,104
207
cow farts, Wisconsin
you should NOT run a 14:00 tire. you need a 12.5 x 20 or 14.5 x 20. A 14:00 tire could and will rub under heavy axle movement in the rear. you can run a 12.5x20 and a 11:00 NDT tire if need be. only use the radial in the front.. never put NDT's on the front and use Radials in the rear.
Alredneck
Banned
1,494
15
TN
Ive squeezed 395s or 15.5s on stock rims but they do rub a lil when playin off road and on full lock right turns. 1400s will fit on the rim but will not fit on the back of the truck not enough space between the axle. ( unless the are really wore out and then it would be real close ) you only have like a 1 1/2 between the tandems with 395s. They look killer and pull good offroad though.
grounded
Banned
928
defiance oh
:ditto: on Alredneck.
I also have a few of 395 and 15.5s left if you decide you are wanting some. I will be bringing a load of tires down to drop off at a members in Birmingham for a few of the southern members in about 1-2 weeks. If you decide you want to go with that size of a tire i can make bring them down on the load.
thanks
EdMontana
TN
I have about 20 new, never mounted TITAN T-HAWK, SIZE 11. 00-20 with tubes. originally for 5 Ton...
emr
25
landing , new jersey
alot of deuce rims are stamped if one cleans em up a bit that max tire size is a 1200. there are alot of guys on here selling tires at good prices, very very good...I love my duel michelins on my deuce, i also loved my duel NDT's on the 925 and just put the 1400 singles on last week, i love them also, I will from time to time run the deuls on the 925, I like veriety and see/feel the differences between them, there are always plus's and minus's for every type and set of tires used, U have a good start in my eyse all U need are 4 tires and rims to have a set up alot of guys drool over including me...
