actionpaintball
- 1
- 18
- Hayes VA 23072
The coolest thing besides the reasonable cost is the extra space gained. Another accessory could more easily be added, like an A/C compressor. Also the primary fuel filter might be more accessible on the M35.
If there is room to add an accessory....could you simply use two 12 volt alternators?....aside from the brackets-you can find the GM based alts really cheap....this would give you 26-28 volts charging and the tap ability to just get 13-14volts as well....not to mention off the shelf cheap replacement parts.
(Is this even an option? I am alternator/generator ignorant).
