Brake fluid.
ken
25
Houston Texas
We started working on the brakes this weekend. And had them working pretty well for about 2 miles. Then the right front wheel cylinder started leaking. It appears to have DOT 3 Fluid in it. Is anybody using DOT 5? Any problems?
m376x6
Colorado
The only thing I have found on changing a DOT 3 system over to a DOT 5 is that you have to completely flush your brake system with a non residue brake flushing compound. Supposedly most brake systems are compatible with DOT 5, I have heard some folks who have had troubles after trying to change over to 5 however, perhaps they didn't flush the system well enough or not at all. Or the cups and other rubber parts weren't compatible with silicone. Even though DOT 5 is not hygroscopic, it doesn't mean that moisture will not collect in the low lying areas of the brake system and will therefore still corrode the brake lines etc..
Regards,
M376X6
papercu
31
Baxley, Ga.
DOT 5 will not help or prevent any leaks and will cost a lot more (money and time). If you drive your truck regular DOT 3 is great. Wayne
nattieleather
142
Cleveland, OH
I agree you need to address the leak issue and then decide whether or not to change. I've used Dot 5 in all my MVs and have been very happy with it.
NDT
6,460
Camp Wood/LC, TX
I put silicone brake fluid in my M135 in 1983 and all 12 wheel cylinders, the air pack, and the master still work great. Dot 3 and it would be a crusty mess. I hate doing work over and over.
ken
25
Houston Texas
Thanks, Guys. As far as the leak goes i've ordered 4 new wheel cylinders. And i already have a master cylinder rebuild kit. We are going to flush everything out and repace the fluid anyway. When we bled them, rust, water and sludge came out of the bleeders. So i can't take any chances. I wanted to keep all my MV's using the same supplies. As much as possable. And that was my thinking of changing to DOT5. I wanted to make sure the M37's cylinders were compatible.
Kenny, Thanks for that info it's a good read.
