USMC Markings
Section 4004.1 says, "Registration markings shall be uniformly applied, using letters and numerals 2, 3, 4, or 5 inches in height. The use of the largest size practicable in the available space will be the determining factor in choosing letter and numeral dimensions."
Section 4006.3 authorizes locally procured self adhesive decals for this, and section 4006.2 specifies that if markings are painted on with stencils,
spaces should neatly filled to provide unbroken lines."
There are no stars anywhere.
There are no other markings specified. If it helps the Mighty Mites that I have seen in original markings have unit markings in diamonds on sides. Also, if it helps, per same manual above, on jeeps the registration # is applied to rear bumperettes. No markings of any kind are specified on any front bumper areas.
Hope this helps,
David Doyle
Another site discusses SOW (statement of work) (Gov site):
USMC registration numbers (serial numbers) shall be stenciled on the left side, right side and rear ofthe vehicle. For the left side and right side, 2-inch uniform letters shall be used. For the rear, 1-inchuniform
Gothic letters shall be used. For both the sides and rear, use exterior black paint (307030,MIL-C-4616
