So apparently these Daniels AF-8's are used in aviation as well........
Looking on ebay, several of the AF-8's have "turrets" with them.
What are the turrets for? Are all AF-8's set up to crimp wire right off the bat or will I need an additional accessory?
Thanks
C
As a former Marine avionics tech (6324/6344) I've used these quite a bit, still do for some applications,
The turrets are used to set depths for different pin and sleeve lengths. the turret can be easily removed , you don't need it for the packard style contacts. I've got 3 sets of these as well as 2 Daniels HX4 open frame crimp sets with multiple dies.
so with all those at my disposal here is what I use when making up packard connections.
Klein Tools -Crimping/Cutting Tools - Non-Insulated/Insulated Terminals
They work perfectly, are easy to use, don't deform the contacts, don't pinch off the wires and can be had for under $25.00 at lowes or home depot. anyone who's seen my truck can attest to what an uptight A**hole I am when it comes to wiring installations.
(comes from working on aircraft all those years)
and best of all , you won't have a fit if they get dropped in the mud, sometimes the simplest ways work best...
