oil filters
doghead
4 Star General /Moderator
1,176
I simply googled 6.2 liter oil filter and found this info.
Ac DelcoPF1218
BaldwinB6/B1428
DonaldsonP166564/P168008/P550035
FleetguardLF3488/LF3679
FramPH13/PH5GM(OEM)12490131/12490145/12490146
HastingsLF224/LF279
International LuberfinerPH1218
Napa1060/1060MP/1061/1061MP
PurolatorL30040/L34631
Wix51060/51060MP/51061
I have a PH5 on mine. I bought it at Walmart.
niferous
Houston, TX
I usually stick with Wix or Baldwin. I will also use NAPA since they are just a relabeled Wix. However there is an O'Reilly by my house that stocks Wix so I just go with those. I generally stay away from Fram and Purolator.
Croatan_Kid
New Bern, NC
You stay away from Purolator? You're the first person I've ever heard say that, please ellaborate.
I used to use Fram, because WalMart sold them and they also sold oil by the case. They quit selling it by the case, so I changed filters and read a filter study where Purolator beat out a lot of others. I use regular Purolators on my older vehilces and PureOne filters on the newer ones.
Of course, now that my CUCV has the Cummins in it, I use Fleet Guard :-D
joeypushjr1
tallmadge ohio
i use nothing but fram in all my vehicles.. and CHEVY79K5 how the heck you say you have a PH13 in your thats fram and the size difference dont make sence to me ...
chevy79k5
libertyville il
first i didnot say i had one i was just asking if it was the right number for the fram. because i cant find one thats a ph13 and acording to this the ph13 is the corect filter Cucv - Steel Soldiers::Military Vehicles Supersite
doghead
1,176
I think the PH13 was longer an had no anti drain valve(possibly no longer in production?). It looks like the PH5 is readily available.
allrevup
Delaware
Here is a list ( the parts guy can cross reference to update) of popular 2 quarts oil filter. All have the standard PF35 base, and fill fit on anything SBC, BBC, 6.2 and 6.5 with out clearence problems if original; Baldwing B7, Delco PF932, Fleetguard LF692, Fram PH1794, Napa 1794, Purolator L40084, Wix 51794, Hasting LF226 thank some call AgDieseler @ ColoradoK5.com.com where I found it 8/03/04
3dubs
Houston, TX
I just put on a Wix 2qt filter. Not sure about the exhaust pipe. But I just rebuilt the engine and need to filter out anything that fell in the engine. But if it does not get too hot I will put another on. Has anoyone used a 2qt filter?
