panzerjunky
- 0
- 0
- san diego ca
Hello Fellas
I have a leak comming from my IP it appears to be comming from between the part that has the 6 injector lines comming out of it and the part that it bolts to there are 4 bolts holding this piece down. Possibly a dried out or otherwise bad gasket. My question is if I remove the 4 bolts and lift the top ip off to change the gasket will the thing grenade on me in a million parts or will it lift off intact? The same grenading question applys for the part that the kill cable runs to as well as the smaller box below that with the fuel line comming out of it and running forward that box also has a safety wire on it. Do I need to take the injector lines off to get the top part clear enough to change the gasket? If so any tips would be apriciated. Lastly what TM would I look at for some help on this issue.
Thanks Jerry
Thanks Jerry
