Rockwell frount end
Barneyszoo
12
Riverside, CA>
Hellow, this is my second atempt at a post, messed the first one up by putting it in the wrong place. I need to replace the seal/dust boots on the frount of my 67 Jeep M35 a2, is this a big job and dose anyone have any pix of this proseager.
Barneyszoo
12
Riverside, CA>
Getting proped to haul water out to the big horn sheep in the Mojave, and the people that give the permits to drive in the preserve do take kindly to leaky axles.
800summit
Soldotna, Alaska U.S.A.
You can do it the easy way, buy the zippered boots, cut the old boots off and install the new ones, that way you don't have to pull wheel,bearings, brakes etc, Silicone the inside and outside of the zipper. done 20 min each side.
on a side note I go through deep water and replaced mine with the new silicone one peice.
lasts longer and is much more stronger
Barneyszoo
12
Riverside, CA>
Thanks, got one of zipper type, but I have the time so I would rather put a solid one one. Also haveing a prob down loading the TMs any help? When I go to that sec. it tells me I'm logged in.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Wrap the axle in depends! A wise "old man" told us about that not too long ago.
Old "Wise Man"!
Barney, follow the link to the step x step. As far as manuals go, there are so many volumes to the 209 series its not funny. I always send new folks to the 361 series, everything is covered in 5 manuals vs some 17 in the 209 series. Once you find the manuals you want to download, right click on them and save them to your computer, they will be available to you all the time that way. The files are large and take some time. Here are the ones I'd start with. TM 9-2320-361-10 and TM 9-2320-361-20. After you digest these or as the need arises, get TM 9-2320-361-34, TM 9-2320-361-20P and TM 9-2320-361-34P. Note, manuals ending in P are parts manuals. As far as boots, I just won't touch another zipper boot. I'd rather force myself to strip the front end down and inspect rather than having the option of the quick zipper boot fix. Good luck, it's not tough at all!
