Help Bad Water Leak on My Deuce
jj9620
Woodlawn Illinois
I've got a M35A2 that I bought at ft reily awhile back I havent started it since I bought it so I put new batteries in today and it fired right up. The problem is that it has avery bad coolent leak just aquick look it looked like coolent was comoing from between the heads HELP any advise what puzzles me is there is no coolent in the oil any suggestions it is a white multi fuel thanks
1,128
If it's coming out from between the heads and there is no coolant in the oil (and vice versa) then it's either a head gasket allowing a little coolant out and it's escaping to the outside without contaminating the oil or more likely a leaking freeze plug.
Read this thread:
http://www.steelsoldiers.com/deuce/11295-all-freeze-plug.html
jj9620
Woodlawn Illinois
Thanks i'll read up on you pictures I'm not familier with these engines I guess I should have said it was not just a leak but with engine running it was pouring I guess to replace the freeze plugs i need to take head off dont mean to sound dumb but im no expert on engines
1,128
Mine was pouring when it was running...... pretty steady stream.
Yeah, the heads have to be pulled to replace the freeze plugs. All the sizes and part #'s are in the thread I link'd.
Don't be scared of it. Not too bad a job.
Banshee365
14
Ocala, FL
Some say that there are 2 types of deuces. One's that have had the heads off and ones that will have the heads off.
If you are going to pull the heads for any reason definetly replace with the newer gaskets, and have the heads decked so you don't have to do it again soon. All it takes it some young GI to overheat the motor a few times and the heads could warp in a convex fashion. If you're going to have the heads off you can get alot of stuff out of the way at the same time.
-Kelly
broman78
great state of TEXAS
-Kelly
I had to look up the definition of getting head decked and came up with two definitions. I would think you are referring to option A because we are talking about a diesel and it already has plenty of compression. Oh would bigger head studs work to keep the head together? something like ARP studs
A) to clean up the surface of the head to give a good gasket seal
B) A deeper cut than done in A, to reduce the size of the combustion chamber and increase compression.
1,128
He was referring to having the head resurfaced so it is perfectly flat.
http://www.steelsoldiers.com/48557-post64.html
I doubt bigger studs would help-the issue isn't fastener failure, it's the inability fo the head gaskets to hold in 22:1 compression.
I agree with Banshee about the "2 Deuces" satement.
1,128
clinto is this freeze plug the one located on the end of the head
Oops, sorry, I didn't see your question.
Did you mean to post a picture with this question?
There are plugs in the top (under the rocker arms) of the head, on the ends and on the manifold side. See my pics in the linked thread for more info. The end plugs leak the most frequently.
dcwilkie
Huntsville, AL
You want to hear something funny? I used to own various British sports cars and never minded working on them. After I got rid of them and had more modern cars, I got to where I couldn't stand to work on the frickin' things. Now that I have the Deuce, I'm back not minding it so much and actually look forward to a job well done! :hammer:
Why? It's all just twistin' nuts and bolts, but I just enjoy this alot more than, say, changing the oil on my 2001 Chrysler Concorde (a car that has been nothing but good to me BTW). :confused:
Have to echo Clinto here- it's not too bad... except the weight of the head! Be careful! I have hernia surgery tomorrow :drool: and it's because I'm a dumesel (Ger.- did I spell that right?) and never ask anyone to help lift the heavy stuff.
How in the aich ee double hockeysticks I'm going to drive an M109 home from Redstone this month is beyond me :doh:
