Picked up a truck the first of this month. Towed it home because some engine parts where removed.
Installed an new turbo because the other one was toast.
Fired the old girl up and no oil pressure. Diagnosed it to no oil flow. Suspected the oil pump was bad. No knocks, noises, etc.
Removed the pan and found two pea sized chunks of metal. and little else. The pan was clean of debree.
One bolt from the scavenger tube was loose and the oil pump idler bearing seemed sloppy.
The questions are:
Can you bench test the pump? (read the manual. No info provided)
Found these posts:
http://www.steelsoldiers.com/deuce-modification-hot-rodding/18785-few-more-ldt-questions.html
http://www.steelsoldiers.com/deuce/32983-need-little-help.html
Does anyone have the part number for the idler bearing?
Any ideas?
Thanks,
Warthog
The questions are:
Found these posts:
Any ideas?
Thanks,
Warthog
