panzerjunky
- 0
- 0
- san diego ca
Hello Gents
Helped my neighbor out today cleared out 5200 Ld of century plants and succulents and hauled to the dump in 3 loads 1st time useing the deuce for work. Largest load was 3200 Lb and she ran like there was nothing in the truck I was impressed.
But........about 2 1/2 to 3 miles from the house I started to smell coolant and knew something was wrong.
Got to a place about a mile and a half down the road pulled over and found my alt,Fan, air comp pump belt was gone the 1st one went a couple weeks ago and the last one today. I was just waiting on new hoses from will to pull it all apart and fix the belts hoses ect.
The coolant was spraying out of the upper hose from between the water neck and the hose clamp.
Questions are
1. when I cleaned my primary fuel filter I had to loosen the belts is it possible that I over tensioned the belts when I got the filter back together as for them both to go this close to each other
2. or were both belts just old and when one went it put all the load on an already bad belt.
3. last and most important question....What is the worse that can happen running this truck 2 miles when overheated.
Thanks Jerry
Questions are
Thanks Jerry
