Oldgrunt
- 1
- 0
- Lancaster Ohio
Does anyone have suggestions for a great cable lube? I have always used liquid grafite on the cables of my Harleys, and it seems to work well.
Oldgrunt
Oldgrunt
I have multiple 5gal bucketsRecovry4x4 said:I've heard bad things about using waste oil. Gimpy, what do you consider a crapload in reference to Pneumatic tool oil?
Well, the ps article says that there is a heavy-er cable lube made specificly for winch cable, but not to use it as it will pick up grit that will ruin the wire strands. Grease might function that way. I'm just regurgitating what I've read.BKubu said:I've heard the same bad things about using oil, Kenny. I use chassis grease.
You shouldn't apologize, members should be thanking you. This is what we want! Find old pertinent threads instead of starting newer duplicate threads!Sorry for resurrecting an old thread.
