- 9,576
- 211
- 63
- Dickson,TN
Ahhhh. I see. Nice.
So, when you have the glad hand connected to a air hose running to a portable tank acting as an extra air supply, what / how do you stop the air flow from over filling the tank? Do you just watch the gauge on the tank and when it gets to 120PSI (just an example) shut off the valve on the truck air line at the glad hand?
I read contrasting suggestions on impact usage on the truck for the lug nuts. Some say gotta have 3/4" drive impact, some say a GOOD 1/2" drive IR impact will be good enough.
I've been going around and around in my head on what to buy and how to configure the air supply for running an impact off the truck. I will likely have to change a tire when I pick my Deuce up, so I need some ability to remove and install lug nuts.
I see guys say go with 1/2" hose all the way, some say 3/8" hose is fine. If I go with 1/2" hose, and use (if I can find) 1/2" fittings to the impact it will still get choked down to 1/4" at the fitting on the impact won't it?
The air governor on the truck shouldn't let you put over 120 PSI in the tank. If your truck builds over 120 PSI your governor needs adjusting.
As far as impact size goes, I've seen lugnuts that wouldn't come loose with a 1" impact without heat from a torch so I'd say you'd need a 3/4" at a minimum.
