Snarky
- 9
- 0
- Brazosport, TX
It would have made it without the wood easy. Put the wood in front of the trailer tires to keep it from moving. The back axles will push the front axle into the trailer, and the front axle will walk it's way up the ramp, the rest is easy. As long as your front bumper clears you're golden, I traversed a 1' or so vertical wall yesterday, it's easy if you just go slow and ease your way into it, shouldn't even need low range to drag you up.
