niferous
- 6
- 18
- Houston, TX
Well I knew it would probably be a good idea to go ahead and change out my glow plugs and glow plug relay. The truck started great after it warmed up but was hard starting in the morning. Sometimes I had to crank and crank the truck. Let off, recycle the ignition, and then crank again before it would start. I went to O'Reilly and got the AC Delco 60G glow plugs and the BWD GPR1 glow plug relay.
All the old plugs came out really easy with none of them being swollen up. I did find out the second glow plug from the front on the passenger side was not hooked up. The glow plug was in there but the wire was not connected. I went ahead and pulled out all the old ones, shaved down the heads on the AC Delco plugs, and installed them.
The glow plug relay gave me some trouble. For one the BWD relay does not mount the same way that the one on there did. It needed much longer screws which did not come with the kit. So to get it mounted up so I could get the truck to the store I zip tied it on snugly. It's less than two miles to the Home Depot where I can get the screws so I'm sure it will be fine. I just ran the zip ties through the mountine holes and secured it to the plate on the firewall.
After I hooked the batteries back up I got in to see how it started. I got home at around 5:30 pm and this was about 2:30 am so it was plenty cool. No drag at all and the truck started right up. I barely had to crank it at all. So all in all I would say it went well. As soon as I attach those screws to more securely mount the relay it should be perfect!
