- 1,926
- 30
- 48
- Irmo, South Carolina
Hey all,
I recently became aquainted with the deuce I won back in March. The truck is pretty solid, however the cabin has about a half dozen trouble areas that are covered with rivited patch plates. Mechanically it performs very well. I recently completed a 1100 mile relocation journey down the I 95 to Ft Lauderdale, Fl. The motor burnt oil at an alarming rate of a gallon per tank the first couple tanks of fuel, then settled down to almost no consumption for the last 500 miles.
When I was checking out my truck pre-trip, I grabbed the in-out lever on the winch and lo and behold, the handle came off in my hand, with a 1" stub of the operating shaft attached. The operating shaft is sheared, and I must assume there will be other maintenance issues awaiting discovery when I commence repairs.
Where should I go to find repair parts for the front winch on the M35A2C? Also, if anyone has the TM number for the winch repair manuals handy, will you please post it?
Thanks,
Rick
Thanks,
Rick
