2009 vin info thread
CARNAC
The Envelope Please.
686
Corpus Christi, TX
a. 12514946 (I think there is supposed to be a "0" in front of the 125). The data plate stamping begins at 125.
b. Registration number is painted over, cannot read it.
c. 23200771617
d. Fort Gillem Forest Park, GA
e. Passenger Front= 81C-R398C Driver's Front= 212
Clinto thinks this should be a Kaiser-Jeep but GL said this was a General Products Division truck. He also thinks the 0125 serial # is '66 or '67 so that should be right. The data plate is for a Deuce with a winch and you can see where the PTO handle used to come through the floor for the PTO.
Much thanks!
She who must obtain a DUKW......... :D
Organization:398TH CHEMICAL COMPANY Location:MILLINGTON
TENNESSEE
Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2 NSN:
2320000771616 Serial Number:
12514946 Registration Number:
4G8938 Year of Mfg:
1965 Manufacturer:
65909
Usage Miles: 40000
Sep 04
I would bet the usage miles is a fudge.
Keep in mind CAGE CODE/BINCS data base was developed in 1974 so at that time they would have went back in time to develop a CAGE number for Kaiser Jeep. In 1974 it got registered as simply Jeep and only later did they develop a CAGE for Kaiser Jeep. It seems this is the same for all trucks pre 74 and a lot post 74. Most likely as they built the database they did active production first (actually companies request their own in order to do business with the govt) and then worried about previous producers no longer around.
RDUKW
11
California
Thank you for all the info CARNAC. Your wealth of information is appreciated as usual. Your link for donations is not working tonight, I will try again later.
Thank you
Ryan
nhdiesel
Milan, NH
Not much info, my data plate is missing...here is what I have:
Frame number: M57334
Registration number: This is on the inside of the door, possibly: 4E0883
NSN: 2320000771616
Bought from: Ft. Knox, KY
Bumper Markings: 1/188 ADA H1O-04
DTID: (hope this helps): W81G1X80435051D
Any info appreciated, donation coming. Thanks in advance. Info needed to register truck.
Jim
Hay Man
Southeastern Kentucky
Thanks in advance for any information you can provide. Here's what I have:
a) 12319156
b) 4H4035
c) 2320000771616
d) Purchased from a private party in Tennessee
e) BJ022
CARNAC
686
Corpus Christi, TX
NSN: 2320000771616
Jim
Organization:1ST BN 188TH AIR DEFENSE ARTILLERY HHB Location:GRAND FOR
NORTH DAKOTA
Nomenclature:
M35A2 NSN:
M57334 Registration Number:
4E08831 Year of Mfg:
1967 Usage Miles: 17113
Info Jan 06
Organization:MAINT ACT KAISERSLAUTERN Location:KAISERSLA
GERMANY
Nomenclature:
M35A1 NSN:
2320005425633 Serial Number:
4E0883 Year of Mfg:
1962
This was when the truck was still an A1 and it was sent to rebuild to A2 standard in Jan 1986. Unknown what unit it came from in Germany.
CARNAC
686
Corpus Christi, TX
a) 12319156
b) 4H4035
c) 2320000771616
e) BJ022
Organization:HQ, 48TH INFANTRY BRIGADE COMBAT TEAM Location:MACON
GEORGIA
Nomenclature:
M35A2 NSN:
12319156 Registration Number:
4H4035 Year of Mfg:
1985
Jan 08
WeBeJeepin
Jackson, MS
I dont know if you can work your magic on a M715, but here it is:
Serial No. 17464
Hood Registration No. 3G0899
Fed Stock No. 23209216366
Found it with a 4-SALE sign on the side of Hwy 18 in Mississippi
Left Bumperette S124
Right Bumperette B95
I believe these to be the original numbers, but it has been painted previously so who knows if somebody changed them. Thanks for the help! John
omega231
Huntsville, AL
Ive gotta couple of 5 Tons that i could use the year on. The help is much appriciated and Ill be sure to donate to the site for each answer. Heres what Ive got:
M818 Kaiser Jeep
S/N: O5B-72670-C124-10988
NSN: 2320-050-8978
M820 Kaiser Jeep
S/N: O5E-81670-C129-10158
NSN: 2320-050-9006
M820 AM General
S/N: NL031Z-C129-10470
NSN: 2320-050-9006
CARNAC
686
Corpus Christi, TX
Serial No. 17464
Unit Ident Code:
WAKSB0 Nomenclature:
TRUCK CARGO 1-1/4T Model:
M715 W/W NSN:
2320009216366 Serial Number:
17464 Registration Number:
3G0899 Year of Mfg:
1967 Manufacturer:
65909
The info is as of Sep 05 but that's not to say it was in service then. The recorded was updated then as a reconciliation but no idea why.
I don't have a unit but do have a UIC WAKSB0. That puts it in a B Company of the unit but no idea the unit. Interestingly enough a fellow member on here, MIGZ, also has a M715 that was owned by this same unit.
Your M715 was shipped to another unit with the id code of WAJZAA but again no info on that unit name either and no idea when it was transferred to them.
Best advice I can do it contact the Army Heraldry folks at Carlisle Barracks, PA and they should be able to tell you the unit and maybe even find vehicle photos (long shot).
CARNAC
686
Corpus Christi, TX
M818 Kaiser Jeep
NSN: 2320-050-8978
M820 Kaiser Jeep
NSN: 2320-050-9006
M820 AM General
NSN: 2320-050-9006
Organization:1177TH TC CO MDM TRK Location:LA GRANGE
GEORGIA Nomenclature:
TRUCK TRACTOR 5-TON Model:
M818 W/W NSN:
2320000508978 Serial Number:
C12410988 Registration Number:
5B72670 Year of Mfg:
1970
Usage Miles: 23995
Feb 09
Organization:38TH INFANTRY DIV HHC Location:INDIANAPO
INDIANA Nomenclature:
TRUCK VAN EXP 5-TON Model:
M820 NSN:
2320000509006 Serial Number:
C12910158 Registration Number:
5E81670 Year of Mfg:
1970
Usage Miles: 26792
Apr 09
Organization:38TH CS HHC HHC SUSTAINMENT Location:KOKOMO
M820 NSN:
C12910470 Registration Number:
NL031Z Year of Mfg:
1980
Usage Miles: 20211
Dec 08 The database say 1980 but I think it maybe a typo and it should be 1970.
ALSO: NO DASHES, it just slows me down having to remove them.
pistonring
Elkton MD
a. Serial Number (VIN number) 032526413
b. Registration Number 04A39870
c. NSN without dashes 23200771617
d. Where you bought it GL at Letterkenny in PA
e. Bumper numbers 99CR ECS 3xx
contract # DAAE0668C007
M35a2 w/w mileage about 15000
Thanks so much for the help:-D
zyrtecx
Western NC
Could you see if you could locate any information on this M101A1 trailer Mfg. in 1968:
a. Serial Number (VIN number) - 744
b. Registration Number - 06JF6368
c. NSN without dashes - 2330008986779
d. Where you bought it - Ft. Bragg, NC
e. Bumper numbers - WQYOAA D0023
Thanks in Advance!
CARNAC
686
Corpus Christi, TX
Nomenclature:
M35A2 W/W NSN:
2320000771617 Serial Number:
32526413 Registration Number:
4A39870 Year of Mfg:
1970
Sep 05 and tracked it to the 464th Transportation Company, Medium Boat, Fort Belvoir, VA
CARNAC
686
Corpus Christi, TX
Thanks in Advance!
Organization:211TH MILITARY POLICE CO Location:CLYDE
NORTH CAROLINA
Nomenclature:
TRLR CARGO (3/4T) Model:
M101A1 NSN:
2330008986779 Serial Number:
744 Registration Number:
6JF6368 Year of Mfg:
1968 Usage Miles: 1109
Info Jan 06
