mudguppy
- 15
- 0
- duncan, sc
Chuck, i agree with everything you said here. people keep asking about reliability and what it will take to get more of it and more power output. those 4 things you mentioned are at the top of the [long] list of design obstacles that is keeping the multi (in its current form) limited in reliability and power output.... I am certain that the MF's problems with reliability stem from a couple of things. First, a turbocharged 22 to 1 compression ratio is a brutal thing to do to an engine. Virtually all turbocharged diesels are in the 17 to 19 to 1 range. Second, the MF piston is a heavy thing. Third, the oil filters should never have been mounted upside down, and above the oil pan. The MF engine runs 12+ seconds with air being puffed through its bearings before the oil filter canisters fill up and provide oil pressure, and Fourth, the Fuel Density Compensator's tendency to leak and dilute the oil kills bearings. ...
oh, and that weight was pulled off of Table 1-4 from TM 9-2815-210-34-2-1 page 1-11.
