Tire Size Comparison 16 vs 14 vs 15.5
M1075
Oklahoma City
I get a lot of questions regarding tire sizes. Here is a comparison pic to show the difference between 16R20, 14R20, 15.50/80R20, all in the Michelin XL tread pattern. They measure about 52", 49" and 46", respectively. Any of these sizes will work as super singles on a 5 ton, with only the 15.5 tires being suitable for 6x6 deuce.
M1075
Oklahoma City
Its nice to get a real world view of the tires side by side.
Thanks!
No problem! I have explained it to customers many times. Most have a hard time grasping the fact that 15.5 is smaller than 14.00. Next time, I need to throw in a "tiny" 11R20 for real comparison!
cranetruck
75
Meadows of Dan, Virginia
The aspect ratio should always be taken into consideration. Like the "/80", which means that the tire is only 80% of the width in height.
The 15.5/80R20 should be 44.8 inches tall going by the numbers, while the 100% aspect ratio 14R20 should be 48.0 inches tall on a 20 inch wheel. Real world measurements will be different, no doubt, depending on tire pressure, wear and tread pattern.
The tires on my 8x8 are actually 16/70-20, which makes them only 42.5 inches tall while they are 16 inches wide (image below compared to 1100-20 NDCC).
No.2Diesel
11
Huntington, NY
Hi,
Thank you for taking the time to take measurements & post pics.
Two questions:
1.) Are the 15.5" 80R20s still in production, if not then on a scale of 1-5 (five being the most difficult) how hard are they to source?
2.) I'm wondering out loud if the above tire can be run as duals in the back for a 5ton application?
M1075
Oklahoma City
Hi,
Two questions:
1) Easy to source. They are used on M1076 PLS trailer and are heavier ply (18) than 395/85r20 tires. I usually have some.
2) You should be able to run these as duals on a bridge truck. There would not be enough clearance on a regular 5 ton.
M1075
Oklahoma City
Thanks Bjorn. What is strange is that 15.5/80r20 is the same size as 395/85r20. It is weird that they have different aspect ratios.
cranetruck
75
The 395s would be 46.44 by the numbers, so they are a bit taller than the 15.5s, but then again, the real world numbers may differ.....
No.2Diesel
11
Huntington, NY
Hi,
Thank you for the clarifications....Do bridge trucks have wider backing plate to backing plate dimensions than a std. 5ton? Different backspacing on the wheels?
Thanks again a picture is worth a bunch of words
jimbo*
Roswell, New Mexico
Do the 15.5's have the same style of bead as the 14.00 and 16.00?
I have a few of the smaller 14.50R20's, and they have the automotive style bead. I see them mounted on combat wheels, but they are not designed for that (truck) style wheel.
tsmall07
Springfield, VA
Anyone have a pic of a 5 ton running the 14R20s? I was planning to run the 16r20s (on the 5 ton I don't even have yet) but am interested in impacting the power less as long as it still looks/performs BA.
