We inherited a 1963 m36.The truck was built by white.The engine seems to run fine with a bit of ether,but is not getting fuel.The fuel pump is on the block under the injector pump,seems to be working fine.The engine has a holley governor at the intake,and is missing something between a vacuum port in the intake at about 9 0clock and a vacuum line coming from the tee where the fuel lines go around the back of the engine to the injector pump.I cant find a fuel bleeder anywhere.Any advice would be greatly appreciated.
