FDC Bypass tools needed?
Westex
El Paso, TX
I've read as many posts as possible, but now my Deuce is 650 miles away after an awful diesel intrusion into the crankcase, and I suspect it's definitely the FDC. Need to fly over and get it in San Antonio, and question is, what tools do I need to bypass the FDC? I know I need some plugs, but do I need a flaring tool to extend the fuel line, etc..
jasonjc
290
Gravette Ar.
All you will need is some wrenches. You can just move some lines, no plugs needed.
Off the top of my head I'd say 3/8,7/16,1/2,9/16" should do it
Floridianson
2,503
Interlachen Fl.
Just be very clean with the final to head line run. One small grain and it might find it's way to the injector. I like to wash with a water hose and good power point tip let sit awhile blow it off and open the systems. Eather oil or fuel systems I do this on.
