Heater installation PICs?
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
OK, thanks for the info.
All I could find on e-pay were $70.
I will order it from newark.
Thanks again. I don't know why my searches didn't turn this up.
Newark turns up in very few searches I do, but you also have to know where to look for it when you're in the business...we use Newark a LOT for work
agood1
Woodstock, Ga
Yeah, I looked at the Newark site and they listed a store in the Atlanta area, I was just going to run by and pick it up.....but I called and they closed the Atlanta store. Oh well, it's on order now....
rlwm211
Guilford, NY
I will be honest and ask if a "LOW" speed is all that important. I have a heater in my deuce and when it is cold enough to need the heater, I need as much heat as it can produce. I almost never use low and I would imagine that unless you insulated the floor, plugged all the cracks and air leaks, you would most likely find out that you would use High almost exclusively. I would install the heater and just wire the high side of the switch and try it before going to any great length to find a resistor to give you a low speed fan.
Just my two cents
RL
Speddmon
Cambridge, Ohio
RL,
You're probably right, but the resistors are EASY to find at Newark and other places, and even with shipping they are probably $10 to $15 for the most expensive ones...so why not.
Speddmon
Cambridge, Ohio
good lord man....how much did they soak you for shipping???? The 100 watt wire wound I linked to you was only 12 bucks
still not terribly expensive though
Tackettr
Edmond/OK
How critical are the "IN and OUT" connections on the heater core? I didn't pay much attention to it when I connected mine. Looks to me that it could be hooked either way and make no difference?
PS: I know the connections to the engine are critical and I have made sure they are correct.
agood1
Woodstock, Ga
$12 something for the resistor, $8 something to ship it and $5 handling fee becuase the order was less than $75.
agood1
Woodstock, Ga
I called the people I bought mine from, and they said it did not matter, coolant would flow thru either way.
