How do the tires in a super single configuration compare to the dually setup in the rear of these trucks stock.
Winch is a work in progress, I'm trying to find one locally, but can't seem to find one and have been told the 5 ton winch fits upside down but works properly and I have a lead on that.
The rear rear already has a locker correct? and the fronts I was debating on a locker as well or atleast locking hubs would that interfere with the air shift?
i have not had my truck when it had duals on it, but have read on here many times that singles do much better offroad than the dual NDTs. there are about 4 ba-zillion tire threads that will offer a ton of interesting reading for you. the short story is that a 46" tire is the largest you can fit on the deuce without the rears contacting each other. so the 395's and 15.50/80R20s are good candidates.
i don't believe that a 5 ton winch will fit on the front of a deuce without some pretty good work. it's been done, and who did it and what thread escapes me right now. this might be able to be dug up with a 'search'..... might.
the deuce does not have a locking differential in stock configuration - all diffs are 'open'. i like lockers in my bob'd deuce but have not driven a standard deuce on the street with automatic lockers in the rears, so i don't know how well that drives. if you've got a decent budget, the ARB air lockers would be the cat's meow for on and off-road - they can be had for ~$900/ea.
i have an automatic locker in the front axle of my truck. this is one of the reasons i am running locking hubs. i believe that a locking diff in the front axle is more valuable than in the rear. again, ARBs are nice but expensive. on the other hand, getting a detroit or Ouverson ultralocker + locking hubs will be about the same price, so the choice is yours.
locking hubs won't affect the air shift - unless you have your hubs unlocked and lock in the front axle while the truck is moving. this could damage the dogs on your front axle engagement collar, so be sure you're locked in and/or stopped before you engage the front axle.
oh, and post pics.
