MajesticSyntax
- 1
- 0
- Weatherford, OK
I have been struggling to diagnose my brake issues since the Oklahoma get together in October. My brakes would slowly seize up the longer my truck was running. I have bled brakes, checked the drums, all that jazz. All of it was fine. I think I have finally figured out what the problem is, but I have no idea how to fix it.
When I got the truck the max pressure of the air lines was regulated to 120. Recently I have learned the the regulator has not been shutting off at that pressure and instead, over pressurizing and eventually locking my brakes. I am upset that I did not see that sooner, but now here's my problem. I took the air pressure regulator apart and cleaned it up and reinstalled it. Now when my truck reaches it's new max pressure of 95 psi it just starts popping off excess air instead of shutting off the compressor. Occasionally the compressor will shut off like it's supposed to, but more often than not, it just blows off the excess air. My question is this: What so I need to do to fix this? The regulator is a really simple device and I'm not sure how it could be repaired, so does that mean my issues lie in the compressor itself? Any information would be greatly appreciated.
CEM
CEM
