Gen 2
T_F_E
Metaline Falls, Washington
Ok so my gen 2 light is very dim, actually I can't see it at all in the day light. To turn it off and move the voltage gauge into the green I have to rev the sh** out of my motor. Both alternators were rebuilt less than a year ago. My gen 1 light is bright and just takes a light tap of the pedal to go out, that is the way gen 2 use to be. Belts are all tight. I'm pretty clueless when it comes to electrical so any help would be much appreiciated.
Thanks all!
Mike
Stihl029
Kodiak, AK
Mine has been doing the same, I have looked into it just a little, however the gen 2 is not charging. I have just been hooking it up to a charger a few times a week and rolling with it till I get a replacement gen 2 in.
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
Can you clarify? Once you've revved it, it keeps charging, or it goes back to the dim light situation?
D10
so. california
i am having same problem. havent checked relay yet if it is bad where can you get another one, and how will you know if it is bad?
DaGlitch
Albuquerque / NM
Yea, you can get them at any napa, advance auto parts, autozone. You could perform a couple of tests on them, but for $5 bucks a piece it's worth it to just replace it to rule that out.
Trying to find a part number, and will post back when i do.
GM PART # 356284
D10
so. california
thanks for that part # i took mine off nothing looked burnt but it is really dusty in there so for a couple of bucks i think ill replace it
DaGlitch
Albuquerque / NM
Not a problem. I couldn't find the napa or autozone part numbers, but they should have em. I just replaced both of mine as well, and it solved a whole bunch of problems :)
