- 4,807
- 736
- Liberty Hill, SC
Hey guys. I thought you might want to take a peek at my remote reservoir setup that I just installed on the M109.
I know others have done this upgrade, but I chose to do things a bit differently. I didn't like the rubber hose running under the cab. Also there was talk of some hoses don't play well with the DOT 5. So, I eliminated all of that. I cut off the little hose barb from the reservoir base, and tapped a 1/8npt for the tubing connector. Then I replaced the vent elbow on top of the MC cap. I ran 1/4 tubing from the reservoir to the MC. Filled it up. It works great, and I mounted it so I can see it under the heater hose if I flip out the side panel. I plan to get a couple of clamps with rubber to attach it to the cab mount and keep it from rubbing and possibly hitting the clutch pedal.
