Need cucv water in fuel sensor from filter base
ida34
33
Dexter, MI
If anyone has an old filter base with the water in fuel sensor let me know how much you want for it. If I do not hear anything by Monday I am going to have to order a whole new base. If you can help let me know.
Chuck
doghead
4 Star General /Moderator
1,174
Somewhere recently, there were new whole bases for about $50. I think they had the sensors in them. It was posted on the forum.
Does the -20P part number come up in a google search? It may be a GM part number.
ida34
33
Dexter, MI
The filter base is used on GM 1 ton trucks and I found a sensor at Autozone. It was $136. I figured a lot of people replace them because a leaking pressure sensor so I was hoping someone had one laying around. I have my eye on the new base but they do not come with the pressure sensor. Changing the water sensor is a lot easier than changing the pressure switch and the new style bases apparently have a slightly different pressure switch. If no one has the switch laying around I plan to order the base tomorrow. They are $54.99 with 12.88 shipping from the source you are talking about. The same place has them listed on ebay for buy it now of $59.99 with 12.88 shipping. I appreciate it but I am pretty cheap. It pained me to have to get a brake booster for my F-350 yesterday.
doghead
1,174
I understand where your coming from.
Pm Clinto, he has a parts cucv, I think.
Also Hawkman in Pa. he usually has cucv parts, and is easy to deal with.
lavarok
33
Fellsmere, FL
The new bases do not come with the pressure sensor as it is not needed.
On the new bases, that port is blocked off. It is only used by the diagnostic circuit, so unless you are using your STE-ICE set to troubleshoot your truck, you will be ok!
The filter bases are on Ebay for less than $75 delivered.
lavarok
33
Fellsmere, FL
I should add, I just installed ( this past week ) a new filter base from the Ebay seller and it works perfectly. Bolted right up, no leaks. No pressure switch needed.
ida34
33
Dexter, MI
Thanks. FAL shooter. I have not heard anything back yet. I was lucky and even though the tip was broken off it still sealed and did not leak. My son was happy but I still do want to replace it. I do not know if the water in fuel light will work at this point without a new sensor. If you got one pm me a price.
Thanks
Chuck
army98
Eureka, Mo
Sorry for the delay, I found mine , pm me with adress ect and I'll send it to you. (you can pay me back for shippping after)
CUCV85
central/ny
On the new bases, that port is blocked off. It is only used by the diagnostic circuit, so unless you are using your STE-ICE set to troubleshoot your truck, you will be OK!
Your best to just get the one the rest of us have purchased!
The one without the sensor!
http://oem-surplus.com/gmwp/gmc.htm?zoom_highlight=chevy+fuel+filter
54.99 plus 12.88 shipping part number 12471725
and it comes damage free with Stanadyne Filter in a GM Factory Box.
The Sensor is completely BOGUS Military Set up.
Your Water in Fuel Light will work, just plug in.
The Fuel Heater "MIGHT" work HAHAHA
again just plug in - and Roll Out...
ida34
33
Dexter, MI
A member should be sending one as I speak. Thanks for the offers. I knew about the base for $54.99 but since the major problem on these is the pressure sensor I figured someone might have a water in fuel light sensor from a leaking block. Mine was not bad and is not leaking so I only need to replace the bad sensor. If I ever have a problem with the block leaking I will get a new one without the pressure sensor.
Chuck
lavarok
33
Fellsmere, FL
Hi,
As I tried to point out previously, the new style filter blocks do not have the pressure sensor since it is NOT needed. On the new style bases, the port is blocked off internally. No pressure sensor required. Bolt them on and they are ready to go. For the price you cant beat it since it includes the filter that normally runs $20+ at the auto parts store.... $22 around here.
I repeat, NO pressure sensor is required on the new style filter bases. Unless your using the STE-ICE set, your not using the pressure sensor on the old base.
ida34
33
Dexter, MI
I understand no pressure sensor is required on the new bases but my sensor and base is not leaking so NO replacement base is needed. I just put around $300 into the thing in the last two weeks, I had to put another $100 into another vehicle and still need to get $240 worth of body parts for my M151. All this adds up to me not wanting to spend $66.79 on the whole base when I was sure another member had a sensor lying around. When I did my first post I thought the broken sensor would leak. It does not so if I could not get one cheap I would probably not have gotten one right now. I agree the new filter base would be better but I did not want to spend the money unless I needed to. My resistance is money based not based on my wanting to keep the pressure sensor. I do not have a STE-ICE and do not care if the pressure sensor on mine works or not. Again, the problem with the older filter blocks was a leak at the pressure sensor. Most people replace them because of the sensor leaking. This led me to think there were a few people with a water in fuel sensor from the replaced filter blocks. The price may not be able to be beat but someone has gifted me one. I was prepared to spend $20 on one but any more than that and I would have just gotten the whole new base. I appreciate the info but I do know the new base does not need the pressure sensor.
ida34
33
Dexter, MI
does someone have the part number for that new base? please
Call 262-244-1262 ask for part number 12471725, $49.99 complete base including filter in original GM box and marked CUCV as well. This is plug and play, no swapping out parts
From another post by another member. They are now $54.99 with $12 shipping.
CUCV85
central/ny
sometimes you just gotta scroll up in a thread, HERE
http://oem-surplus.com/gmwp/gmc.htm?...vy+fuel+filter
again just plug in - and Roll Out... u just gotta scroll up in a thread
