- 10,350
- 75
- 48
- Meadows of Dan, Virginia
Having taken apart a number of the SW heaters (the Benmar heaters don't use a wick), I have found that the wick has either been burnt to a crisp or been very sooty. The wick is vital to the operation of the heater, it brings the fuel into the vaporizer and I suspect that the kind of fuel used contributes to the problem.
Reading about "kerosene" space heaters, you'll find that diesel is not a fuel of choice, it ruines the wick in short order. K1 clear kerosene should be used and the same should apply to our MV heaters.
My solution is to run the heater from a separate fuel tank, which gives me the option to run it on anything, certainly not biodiesel/veggie or used MO.
Just a heads up if you have trouble keeping your heater running or even starting.
The image shows a jerry can marked "Diesel" for this purpose and any fuel can obviously be used regardless of what's in the main tanks.
