- 3,256
- 3,355
- NORTH (Canada)
When driving for a prolonged time, especially at highway speeds, I have oil leaking from what appears to be somewhere in the front upper region of the engine. When you open the hood, the front inner part of the hood is oily; it looks fan-blown, but I am not sure if the oil seeps out somewhere in the fan area and gets blown back or if it sprays up (from the oil filler cap?) and then gets messed up by the air stream from the fan. It eventualy seeps out where the bolts are that hold the hood brace in place; the bolt heads on the outside of the hood get oily.
Also, the short coolant hose on the passenger side is always very oily (probably same reason; oil been blown back from the fan).
It drives me nuts; the leak is not much in volume it appears. In the region I suspect there is not much stuff that carries oil. I have steamed down the (otherwise clean) engine several times and tried to locate the leak. Nothing detecable at idle, even at higher rpm. Looks bone dry. Once on the road and under load it seems to accumulate.
When I got the truck and stopped at westfolk's place, we re-tightened the valve covers and that seemed to have helped. I am just not sure that is what it is.
Any suggestions? Can the oil filler cap be a culprit? It does get oily up there but I do not know if it is just oil dripping from the hood.
